Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-21-2011, 03:24 PM
Autonow is on a distinguished road
Laser Wood Cutting
Has anyone had success cutting wood with a laser?
I have been able to cut up to about 1/8" thick with minimal burn marks and burning. But anything thicker that leaves an ugly surface! My best results have been to run at 100% power 60Watt and increase the feed until it is just cutting through. Lower power and slower speeds make more charcoal
My Ideal thickness I want to achieve is 1/4"
Old 04-21-2011, 03:33 PM
Gold Member
Ken_Shea is on a distinguished road
Autonow,
I do not have a laser (yet, working on it) but Art from Mach3 fame indicated that he did best cuts when he dipped the wood in water to get it somewhat wet first. If that's the case you may be able to slow it down a bit for a deeper cut.
Don't know anything beyond that but it may be worth a try.
Let us know.
Ken
Old 04-21-2011, 04:18 PM
zax15uk is on a distinguished road
The results depend greatly on the type of wood, but air assist using an inert gas will help.
Zax.
Old 04-22-2011, 12:46 AM
Dennis Rech is on a distinguished road
What type of wood are you trying to cut?
I am using a FSE 40 watt and it does a great job on 1/4 inch poplar.
70% power and about one inch per 5 seconds speed. Some types of wood do not work nearly as well. Pine sometimes catches on fire and leaves a lot of oil in the machine. Not much luck with 1/4 inch 5 ply plywood. The glue causes problems. Oak cuts erratically, the grain can be problematical. I was told that walnut works well.
I give a light sand job to the surface to remove a bit of smoke stain. The edges are going to look dark, but they are not charred much at all.
This is what poplar looks like right out of the machine.
http://www.cnczone.com/forums/attach...1&d=1303450445
Old 04-22-2011, 02:19 AM
ASTECH_CNCTools's Avatar
ASTECH-CNCTools
ASTECH_CNCTools is on a distinguished road
Cool wood router bits & wood laser cutting
Yes, for wood laser cutting, need to pay special attention is: easily catch fire!
If not suitable laser power set, and right cooling system, this situation happens sometimes.
And for different wood materials, such as hard or soft wood, and different work demand, such as cut down, or surface machining, also with different processing methods.
Besides, if for 3D Relief sculpturing demand, then CNC Router should work best.
With help of different wood router bit models, the CNC machine can develop various beautiful artworks.
By the way, for professional settings, it also needs time to know and grasp. Try more, and you will be technical too~
Good luck!
Name:	CNC Engraving Bits for 3D Stone Artwork -ASTECH CNCTools.jpg‎
ASTECH Tools -Professional Router Bits, Diamond Tools, CNC Tools Manufacturer.
Website: http://www.astech-cnctools.com/
Email: astech.cnctools@gmail.com
Tel: 0086-531-89006595
Old 04-22-2011, 09:29 AM
Zax.
I am currently using an air assist but I like the Idea of inert gas.
The wood I was using was douglas fir since it was readily avail for test runs and free. My preferred wood would be Baltic Birch plywood. but other woods would be in the domestic hard wood category
Old 04-22-2011, 10:57 AM
Rodney Gold is on a distinguished road
Inert gas won't help much , a lot of the "charring" is due to resins and other stuff staining the cut edge. The heat a laser generates is not only due to O2 being present , the wood will still char with the inert gas , we have tried it. You will also have issues trying to flood the enclosure with inert gas and not having the exhaust , which is vital when doing wood , suck it out , just using inert gas in the air assist wont work well at all.
A lowish power laser is not a suitable tool for cutting thicker woods , if you have a hammer , not everything is a nail....
Old 04-22-2011, 01:59 PM
Litografa's Avatar
Litografa is on a distinguished road
Here is Baltic Birch plywood cutting without any finishing. As you can see quality is very good.
About inert gas - it work extremely well with different plastics and agree with Rodney that for wood it will not work effective
Name:	Danila liepaja 3.jpg‎
ID:	132177   Click image for larger version
Name:	Danila Liepaja 4.jpg‎
ID:	132178   Click image for larger version
ID:	132179   Click image for larger version
Old 04-22-2011, 02:22 PM
I agree that laser cutting some wood results in dark edges from resins, and this cannot be prevented, but where the inert gas helps is if you are getting flame-ups that are burning the edge (charring) or creating a lot of smoke and contaminating the surface. The original post mentioned burn marks and charcoal, so the suggestion seemed relevant.
Baltic Birch ply with interior glue seems to be one of the more laser friendly products compared to many other woods (especially ply).
Zax.
Old 04-22-2011, 03:37 PM
Great. What power laser go you have? What was the power setting and feed rate? Was the material 1/4"?
  #11   Ban this user!
Old 04-23-2011, 01:03 AM
Litografa's Avatar
It was done by my customers
1) First two with Spirit GE 30 Wt made by FORTIUS marketinga agentura Speed 2%, power 100%
2) Another two with Spirit GE 60 Wt made by ?RAMUSTA? - graviravimas ir pjovimas su lazeriu - NAUJIENOS
Speed 3% Power 100%
Material was 3-4 mm plywood, not sure how much it will be imperial .
  #12   Ban this user!
Old 12-08-2011, 07:09 AM
coase is on a distinguished road
Think about glass laser tube 100w or more. It would be better.
Newbie- What CO2 Laser for cutting 9mm Birch Wood? aussiemate Laser Engraving & Cutting Machines 18 07-27-2010 11:53 PM
Laser for wood cutting- genaral questions adamchapman Laser Engraving & Cutting Machines 7 05-12-2010 01:36 AM
wood laser cutting and engraving machine goldenvivian CNC Machining Centers 0 05-08-2010 01:47 AM
ITOP--CNC ROUTERS, LASER ENGRAVERS, LASER CUTTING MACHINES, CNC PLASMA CUTTERS oliver9866 Product Announcements & Manufacturer News 0 10-17-2008 10:17 AM
which laser for wood cutting colormecnc Laser Engraving & Cutting Machines 4 09-14-2007 01:05 PM
