Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-19-2011, 07:37 PM
dhenss is on a distinguished road
Corel X4 and Data Matrix 2D bar code
Good evening,
I am working on a project were I will be creating a series of equipment ID tags. The customer requires the tags to be sequential, have a Data Matrix 2D bar code and a 4 to 5 digit number. I will be using Corel X4 for the design work, and I will be laser engraving the tags in runs of 25 to 100. My question is, what is the best method for generating the 2D bar code inside of Corel? Is there a plug in, or a font that will work? The project could be as little as 100 tags and as many as 3000 tags, so some automation is required.
Thanks for your comments and suggestions in advance.
Dieter
Old 04-20-2011, 09:15 AM
bobsch's Avatar
bobsch is on a distinguished road
From CorelDraw Help:
1.
Click Edit then Insert Barcode.
2.
Follow the instructions in the Barcode wizard.
If you need help with choosing options, click the Help button in the Barcode wizard.
A bar code is inserted into a drawing as an object.
Bob
"Bad decisions make good stories."
Need Help!- Absolute position data lost ATC Matrix VCN 510C nexuss Mazak, Mitsubishi, Mazatrol 2 11-19-2010 10:37 AM
Newbie- Need software help... Corel Draw to EMC2 g-code pencilneck DIY-CNC Router Table Machines 12 10-20-2010 03:00 PM
Need Help!- Alarm code 1224 on Matrix control spartus333 Mazak, Mitsubishi, Mazatrol 2 07-23-2010 03:28 PM
need help with converting corel to g code pfcary1 Commercial CNC Wood Routers 3 01-07-2007 07:09 AM
Can you make G-Code With Corel Biggermens General CAM Discussion 6 10-29-2005 10:15 PM
