Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-05-2011, 04:00 PM
bpoulin is on a distinguished road
Cor-Plast???
Does anyone know if Cor-Plast is safeto cut? I don't know what it's made of? I think it may be PVC but I can't seem to get a straight answer.
Old 04-05-2011, 05:14 PM
baksiidaa is on a distinguished road
It looks like it is made of polypropylene. A web search turned up a page saying that laser cutting polypropylene releases benzene (a carcinogen), but Universal says on their web page that you can cut Coroplast, and a number of other pages talk about cutting polypropylene.
Old 04-05-2011, 05:27 PM
I looked through Coroplast's health and safety info and MSDS and they don't say anything about benzene. People on the Sawmill Creek forum have cut it.
Old 04-05-2011, 06:35 PM
zax15uk is on a distinguished road
As others have stated, Coroplast is polypropylene and can be laser cut. It may produce some noxious fumes so ensure you have adequate exhaust.
In my experience you need more power than you think to get good results. A 60W system will be fine.
Zax.
Old 04-06-2011, 01:19 AM
EXLASer is on a distinguished road
set power 80%
Agree Zax,
your laser is 80w ,just set power at 70-80%.
Mike
Zax.
Old 04-06-2011, 11:19 AM
Litografa's Avatar
Litografa is on a distinguished road
I was not happy with quality of cut - edge is molted too strong. Cutting need higher air flow in air assist and non-stop attention as material is flammable. So replace your laser with OLFA knife
Old 04-06-2011, 11:43 AM
I actually like the rounded edge it has since cut Coroplast can be sharp, but I can also see how this may not be desirable depending on the application.
There may be different versions of similar corrogated plastic so be careful as they could be PVC or some mix.
Zax.
Old 04-07-2011, 10:26 AM
I am not looking for a commercial use for it. I just saw some folded coroplast boxes at wally world, and thought to myself... Humm this could be fun to make some 3D dinosaur models out of that stuff lol. And that got the mind rolling. I use coroplast for signs but I've never lasered it.
Old 04-07-2011, 01:22 PM
Coroplast dinos would be perfectly fine, you may also want to pick up a package of their EVA foam (foamies). Dollar Tree has it too, and as the commercial says 'everythings a $1'. Example: http://www.joann.com/joann/catalog/p...RODID=prd28413
Zax.
Old 04-14-2011, 09:08 PM
dmoore is on a distinguished road
Question
Zax.
It is all possible for you or anyone else cutting coro to post some detailed photos showing the cut quality?
I currently CNC cut 200-400 sheets of coro per month in some pretty intracate shapes and we spend some time sanding/cutting the edges to get good edge quality our customers are ok with. I would be great to have a product that comes off the shelf into the box without that additional post processing step. Another big problem with have with machining it is that it creates lots of what we call "coro flake" which has to be blown out of the flutes - again yet another manual operation.
  #11   Ban this user!
Old 04-15-2011, 11:40 AM
Laser will produce a 'soft' edge and eliminate your sanding and flakes but intricate shapes may be a problem as the melting removes sharp corners so a square will have a radius on points.
I don't have any pictures available right now but if I have some material I can cut some next week.
Zax.
