Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-02-2011, 11:30 AM
pantallica is on a distinguished road
vl-200 engraving table error
i can use my honeycomb table no problem, but when i try to engrave on the engraving table i get the following error.
a fixture or table seems to be incorrectly attached tot he Versalaser's engraving platform.
Things I have already tried.
-made sure fixture is set to none when i print in corel draw and send it over to versalaser control panel
- talked ot techs upport at universal laser and made sure all the pins RE correctly set up
-honeycomb plate works fine
Need Help!- versa laser vl200 engraving table needed pantallica Laser Engraving & Cutting Machines 2 03-25-2011 10:41 AM
Engraving table on B'Port rjnewbould Engraving Machines 0 03-18-2011 08:53 PM
ALARM!! TOOL TABLE ERROR'' MC MATSUURA 510V victorcnc General Metal Working Machines 0 03-05-2011 11:19 PM
Error in table position for z axis, Mazak FH6800 sonu Mazak, Mitsubishi, Mazatrol 3 12-21-2010 12:08 AM
Post here? Refurbish engraving table Electech DIY-CNC Router Table Machines 15 11-29-2007 06:43 AM
