Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-22-2011, 11:06 PM
pantallica is on a distinguished road
cant cut with versalaser 25 watt vl200 samples?
I can engrave using coreldrawx5.
However i tried drawing a box with a redline to cut through a .25" piece of wood. and all it did was engrave it very lightly.
My laser is used, I'm not sure if a lens is bad, or what my issue is.
To see if its operator error with corel draw I was wondering if someone could send me a sample file for VLS or coreldraw and a picture of how it turned out on your laser, just so i can see if the machine is working properly.
Old 03-23-2011, 12:07 AM
Litografa's Avatar
Litografa is on a distinguished road
What is your red line thickness? Schould be hairline.
How it looks during cutting? Laser move according line drawing for cutting?
And what is your settings for engraving and cutting?
Old 03-24-2011, 10:25 AM
bpoulin is on a distinguished road
Is it going right to left over and over again drawing the box like an inkjet printer, or does the laser head move in a square motion then stop?
Old 03-24-2011, 01:50 PM
Litografa's Avatar
pantallica - you have put here few questions, cnczone members trying help you and it's look not good when you just ignore your own topics
Old 03-26-2011, 10:25 AM
sorry for the lack of response one mirror had a crack in it. Replaced the the mirrors and now we are good to go.
It doesnt always cut all the way through but thats just going to take trial and error on different types and thicknesses. Thanks for the responses.
My red was also a wrong shade so i changed my color pallete.
As far as motion it moves left to right. I am confused though because sometimes it cuts out the shape then engraves inside it. other times it will engrave the inside part first then cut out around it. They were seperate projects so I don't know what I did differently.
Old 03-26-2011, 09:58 PM
Did your laser come with any other software to use besides Corel draw? What is happening is it's being sent to the laser and it's telling it what to do first, you can set the order of when it cuts and when it rasters separately, I don't know how to do this in Corel. Does it use another program like lasercut, or newlydraw?
Old 03-27-2011, 02:13 AM
kewlkiwi's Avatar
kewlkiwi is on a distinguished road
Using object manager in Corel, you can specify the order by having the first item at the bottom of the list, and the last at the top.
Bob
For Sale - HPDFO upgrade for VersaLaser VL200 jalles Laser Engraving & Cutting Machines 1 07-28-2011 08:05 AM
Used VersaLaser VL200 - 30 watt for sale jalles Laser Engraving & Cutting Machines 2 01-18-2011 05:30 AM
Lightly used VersaLaser VLS2.3 w/ 30 watt for sale jason w lynch Laser Engraving & Cutting Machines 3 08-16-2010 03:55 AM
ULS vl200, m-300 cj8n@mac.com Laser Engraving & Cutting Machines 0 07-22-2007 03:21 PM
Tutorials , exercices, samples , mold samples engrsc Solidworks 4 02-22-2007 09:24 AM
