Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-21-2011, 08:46 PM
piranah is on a distinguished road
Unhappy Output coupler leaking
I used hydrochloric acid to clean out the tube and now the output coupler is leaking. Do I need a new tube or can I just replace the coupler or reseal it or something? Thanks!
Old 03-21-2011, 11:38 PM
bpoulin is on a distinguished road
A. Why did you use hydrochloric acid to clean it?
B. Did you get any on the hose? Most hoses are rubber, vinyl or neoprene. All 3 I believe will be eaten by any trace of HCl. Also any rubber seals in the pump, or flow sensor will be eaten up... I would try replacing the hoses first before the tube. Not to mention it will eat just about any metal, so if you have a chiller... Not good.
Here is a link to what is compatible with HCl and what is not. Cole-Parmer: Compatibility Results
P.S. is this a glass tube?
Old 03-22-2011, 12:18 AM
Some metal nuts had fallen into the water and accumulated rust, the tube had scale in it. I searched online and came across this that says use a diluted mixture - CO2 Laser Tube (18W-100W) - China Laser Tube,Co2 Laser Tube,Co2 Laser in Engraving & Etching Machine
On the plus side the tube is completely clean now I'm able to run the water through the tube without a leak by detaching the small hose that goes to the coupler and running directly to the tube. I'm wondering how hot the coupler will get, can I run it without cooling the coupler? Yes, it is a glass tube. I saw some places that will replace the output coupler, does the gas have to be recharged?
Old 03-22-2011, 12:22 AM
Talking
Once the CO2 is out you're done, you need a new tube. I thought it was a coolant leak. In the future keep your nuts out of the water... Sorry couldn't pass on a good pun...
Old 03-22-2011, 12:26 AM
No, it still works, the gas is not leaking. Only the coolant is leaking around the coupler. I detached the coolant from the coupler and the laser is working. I'm just wondering:
A: If I replace the coupler / cooler assembly will the gas need to be recharged?
B: How long can it cut before the coupler overheats?
Old 03-22-2011, 12:31 AM
Ok can't help you there, I haven't been through that, hopefully someone else can chime in.
Old 03-22-2011, 03:14 AM
geekinesis is on a distinguished road
Hi
It will overheat within a few seconds without cooling. The tube is working but I imagine it wont for long as once the seal on the coupling is broken, gass will be leaking, even if its very slow.
rabbit / ls3040
Old 03-22-2011, 03:26 AM
Tweakie's Avatar
Tweakie is on a distinguished road
You must use the cooling jacket on the OC - do not run the tube without it.
These appear to be fixed / sealed with epoxy so clean up the area in question and apply epoxy as necessary to effect a good seal.
If a tube overheats the epoxy holding the mirrors softens and the internal gasses can be compromised, lets hope this has not happened in your case and all will be well.
Tweakie.
CNC is only limited by our imagination.
Old 03-22-2011, 03:37 AM
Thanks for the feedback so far. I've been able to use it for a few minutes here and there and the coupler hasn't gotten that hot. I'm wondering if I can somehow reseal the coupler - put some fix-a-flat through... Or clamp on an external metal coolant fixture.
Old 03-22-2011, 03:46 AM
Tweakie's Avatar
Risky to clamp anything to the tube, differential expansion and all that, best to use epoxy.
Tweakie.
Tags
cleaning, output coupler
Problem- SL-20 is leaking hydraulic oil from the drawbar. TXFred Haas Lathes 2 07-23-2010 10:19 PM
Coolant Tank Leaking mekp21 Mazak, Mitsubishi, Mazatrol 2 07-15-2010 12:05 PM
Need Help!- FJV-250 Splindle leaking oil! Hastx Mazak, Mitsubishi, Mazatrol 3 05-29-2010 01:44 PM
Leaking actuator troubleshoot MadMax Daewoo/Doosan 3 08-28-2009 02:24 AM
SL-10 leaking like an old dog? shawncnelson Haas Lathes 1 11-05-2008 02:42 PM
