Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-20-2011, 09:47 PM
SigUser is on a distinguished road
budget fume extractor/HEPA
right now i am externally venting my laser (which is primarily used to cut 1/8" acrylic). It's really stinking up the place though, cause the hoses being used, and the length the hoses have to run. so i really want to get a fume extractor/HEPA filter, but i want to know about budget choices. Can i hook up a big fan to some sort of HEPA filter from Grainger? Anyone got some mild DIY setups (not full builds). or links for fume extractors < $600?
Old 03-21-2011, 12:06 AM
Litografa's Avatar
Litografa is on a distinguished road
Here
Support | LITOGRAFA : GLOBAL VIEW - LOCAL TOUCH
download file named "DIY 3 stage filter for laser engraver"
Old 03-21-2011, 12:19 PM
zax15uk is on a distinguished road
(ok, probably not the 'greenest' advice... but)
A HEPA filter will only remove the particles (and seriously restricts the flow), for the odor you'll need an activated carbon / charcoal filter or equivalent.
I would actaully suggest you keep with the external venting, but perhaps add a booster fan at the exit. This will help draw the air out and prevent small leaks from letting odor into the shop.
Zax.
Fume filter seen Laser Engraving & Cutting Machines 1 10-06-2009 01:42 AM
Lincoln miniflex portable fume extractor fs on eBay no reserve! Edster EBAY ADS 1 08-05-2009 10:13 AM
Laser Fume Extractor soetaw Laser Engraving & Cutting Machines 6 08-04-2009 06:18 AM
Wood Dust & Welding Fume Extractor diarmaid Safety Zone 12 06-26-2006 02:48 PM
DIY Dust Extractor on a limited Budget. Imagineering WoodWorking 4 12-05-2005 07:28 PM
