| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
| Not sure, I have a CW-5000 chiller and I run 50/50 automotive antifreeze/distilled water without any problems. Maybe flush the system out good with fresh water and refill it with a new mix, maybe some detergent from manufacturing was still in the tank??? That's my only guess. |
| If you let it run for awhile does it clear up or stay foamy? I just changed the water in mine yesterday and I also use distilled water and propylene glycol anti-freeze. When it first started with the fresh water it did produce some bubbles, but they cleared up in about a minute. Did you use pure propylene glycol mixed with water? I think the PG antifreeze has an anti-foaming agent added. Last edited by SkipW; 03-17-2011 at 09:46 PM. Reason: spellcheck |
| the longer you let the cooler run the foaming issue gets even worse....i decided to drain the system and refill with de-ionized water...i think im gona leave it with plain water for now ....too anxious to get the darn thing going. ![]() ....I actually took some of that mixture filled half a container an shacked it for a short while....it nearly filled the container with foam.....what the hell.. |
| Foaming for me always meant either air trapped somewhere or air being sucked into the system somewhere. Use pure water and aluminum safe anti freeze. DO NOT ADD CHLORINE BLEACH as it will corrode the water passages shut in the tube within a few weeks, trust me
__________________ www.classicplayfields.com |
| New Machine Build- We supply you CO2 laser machine also laser tube | masterandroger | Laser Engraving & Cutting Machines | 0 | 12-23-2010 09:41 PM |
| 70w laser tube | lamicron | Laser Engraving & Cutting Machines | 5 | 12-10-2008 08:19 AM |
| Laser Tube Help | FlyGuy007 | Laser Engraving & Cutting Machines | 14 | 09-06-2008 02:50 PM |
| Is my laser tube ok? | PaioX | Laser Engraving & Cutting Machines | 4 | 07-23-2007 03:34 AM |
| bad laser tube | CNCadmin | Laser Engraving & Cutting Machines | 40 | 07-03-2007 10:23 PM |
