Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-02-2011, 10:17 AM
jeade is on a distinguished road
Cutting 1/4" Stainless
I'm using a 2000W Mitsubishi laser cutter to cut through 1/4" T304 Stainless and am having a lot of problems with dross adhesion to the back side of my parts. I have increased and decreased my gas flow rate and have re-centered the nozzle over and over again but to no avail.
Anyone have any suggestions to get these to cut better?
Thanks.
Old 03-02-2011, 01:08 PM
keebler303 is on a distinguished road
I've done a limited amount of cutting on 0.050" stainless with a 150 W laser. I had some problems with dross on the back side as well. It sounds like you have only played with the gas flow. Can you adjust the power of your laser? You can change how fast you are going. Playing around with all three can get you better results. You just have to dial it in for your machine. What gas are you using?
Matt
Old 03-02-2011, 01:47 PM
baksiidaa is on a distinguished road
I've read some suggestions of coating the back side of the material with milk of magnesia to prevent adhesion.
Old 06-10-2011, 02:22 AM
zigiboi is on a distinguished road
Cool Dross
I have a 1600W 3015HC located in Paris MO 660 327 4263. Sounds like a too slow feed rate, or your Power is Hot. If you see pockets in the kerf, I have learned that the gas pressure (I call, "blow") is too high. The metal is molten in the middle before bottom is punched and the high pressure creates a mess in the middle.
On mine, I think I was pushing the limits at 3/8" on steel, so I just threw a nice wide nozzle on the plasma cnc and it made an awesome cut.
Nozzle diameter: Toy with that too.
Gasses: Use dry shop air in the meantime for experimenting. Save some $$
Hope it works out for ya.
Z
Old 06-10-2011, 08:00 AM
amada_allparts is on a distinguished road
Thumbs up About the laser cutter
About your problem , i can advice you to use AMADA's laser cutter!! which is more precise and clean. You can get one of these devices from these sites where you can buy new or an used device. Alternative Parts, Inc | Amada & Fanuc Replacement Parts & Alternative Machinery Commerce
Old 06-10-2011, 08:19 AM
LOL, I have an easy solution, just buy a new $500,000 machine, its simple.
Old 06-11-2011, 07:52 AM
krisik is on a distinguished road
If you'd like to be ripped off by a used machinery dealer or would like to buy a cheap low quality part for your machine - follow the thread.
Tags
cutting, laser, stainless steel
Trumpf TCL3030 cutting parameters for 3/8" Stainless Electra Laser Engraving & Cutting Machines 2 08-07-2011 08:43 AM
WTB: 18" diameter .125~ wall stainless tubing, 18" long piece m-134b Want To Buy...Need help! 2 03-02-2010 07:14 PM
Need A Quote- RFQ: Small (3"x5"x1/2") part from dimensioned drawings in Aluminum or stainless octathorpe Employment Opportunity 6 06-23-2008 07:14 PM
How/what machine to shape a thin stainless plate to become a "half" egg shape ? Calico General Metalwork Discussion 5 03-24-2007 09:40 AM
Alternatives to "Solar flux" stainless welding flux? chingon Welding, Brazing, Soldering, Sealing 2 03-12-2007 05:34 AM
