Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-01-2011, 04:48 PM
bpoulin is on a distinguished road
LMM14 thermark settings????
I'm trying to figure out settings to use thermark, this stuff is expensive so I don't want to just play around with it. I have LMM14 and here is a link to their website and suggested settings. I just can't figure out how to translate this to my machine. I have an 80w CO2 setup. So it says for stainless steel 41w, roughly 50% power for me, but it says 98ips which is 2489.2mm per sec That's insanely fast, That has to be an error, I don't know any co2 setups that are 98ips. So what would you recommend starting out at for power and speed?
Old 03-02-2011, 07:12 AM
twehr is on a distinguished road
Calculation
ipm * 25.4 / 60 = mm/sec
91 * 25.4 / 60 = 38.5 mm/sec
So, first test for you should be about 40 mm/s at 50%. Then adjust from there.
Old 03-02-2011, 09:32 AM
If you go read the chart it's 98 ips not ipm
Old 03-02-2011, 09:36 AM
Correction
I see that the chart does say in/sec, but I don't believe it. I have used this with a 40w laser and cannot image going that fast. That is over 8 feet per second. When I use it, it is more in the 20-30 mm/sec range. Any faster than that and I have never been able to make the engraving "stick". It just flakes off.
If anyone else has experience, let us know.
Cermark, Thermark, or ??? on brick & stone aocarving Laser Engraving & Cutting Machines 27 03-06-2011 03:03 PM
Newbie- Settings Help... JHBarber Haas Mills 3 12-15-2010 11:35 AM
Need Help!- Cermark/Thermark Lm-6000 desibrown Laser Engraving & Cutting Machines 7 03-12-2010 05:13 PM
We Cim cut settings slammedxonair DynaTorch 2 11-17-2009 03:50 PM
Need Help!- Mach3 CV settings vs. G-100 Plugin CV settings Bfarn Machines running Mach Software 7 12-17-2008 10:45 AM
