Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-20-2011, 02:27 PM
shaun091382 is on a distinguished road
Layout For Uneven Surface
Hi there, I have had previous experience using a vinyl cutter in the past and was looking at getting into some work with a laser engraver.
I was wondering when using a co2 engraver with corel or adobe or whatever software is supplied. How does it work when cutting on an uneven surface.
Ideally a person probably would like NOT to do this however I'm sure it happens time time....how does the machine compensate for that?
Do you have to set it up in the software? or does the machine auto focus with its lense? Does that cause the image/pattern to be distorted? Just wondering how that works?
Thanks!
Old 02-20-2011, 03:32 PM
Litografa's Avatar
Litografa is on a distinguished road
Depend from what you mean UNEVEN. If it's 1-2 mm - you don't need compensation at all, as laser focus allowed cut/engrave slightly out of focus. If you talk about bigger change - up to 5 mm - possible solution is multi pass cutting with different focusing ofr each pass.
Old 02-20-2011, 07:18 PM
Ok I get what your saying....what about say like a half sphere..or anything with some sort of arc...I guess ideally a person would have a rotary attachment for such a thing?
I guess an extreme example would be lets say the inside of a stainless dog dish (bowl) even a shape of such flipped upside down
Old 02-21-2011, 12:26 AM
Litografa's Avatar
General: of course if you have some kind of arc - you need rotary.
Dog dish - I afraid you need NdYag laser to engrave on it.
Old 02-21-2011, 09:48 PM
Ok! Thanks for the response...I was thinking there might be some trickery with software to be performed but if it is a limitation of the hardware then I can accept that from a co2 basic machine
Thanks!
Need Help!- Fillet surface to surface problem vincent13 Mastercam 6 02-10-2011 06:15 AM
Uneven table compensation crane550 DIY-CNC Router Table Machines 10 09-01-2010 11:31 PM
Engraving and uneven surfaces phatjap DIY-CNC Router Table Machines 8 04-21-2010 07:11 AM
Uneven finish orbyog Mach Software (ArtSoft software) 13 02-05-2010 01:42 PM
Need Help!- Surface to Surface Filleting and Trimming cowpoke Mastercam 6 03-17-2009 08:42 AM
