Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-15-2011, 12:29 AM
echojdlaser's Avatar
echojdlaser is on a distinguished road
Leather Laser engraving cutting question
Hello everyone,
We have tested leather laser engraving cutting, for processing area are black.
Who have any idea on dealing with black part?
Echo
ID:	126555   Click image for larger version
Chinese Manufacture, exporter for Laser Machine, CNC Router
Web:www.jdengraver.com Miss Echo: jd.market32@hotmail.com
Old 02-15-2011, 03:56 AM
Litografa's Avatar
Litografa is on a distinguished road
As I understand right you want DO NOT HAVE BURNED EDGES during cuttng?
Old 02-16-2011, 09:03 PM
about leather processing
Dear friend,
How to avoid buring the edge? How to deal with?
It is the point.
Echo
Old 02-16-2011, 11:21 PM
bpoulin is on a distinguished road
I'm not sure you can cut leather without burning it, that is how the laser removes material, possibly multiple low power passes???
Old 02-17-2011, 12:40 AM
Litografa's Avatar
We did a lot of test with main question HOW WE CAN AVOID BURNED EDGES AT ALL or at least lower level of burning. Best results were achived with argon instead pressed air in air assist. But it was most expensive solution. Second place belong to nytrogen, and third to CO2 (cheapest one). So replace air in air assist with some gas which do not support burning.
Old 02-18-2011, 11:48 PM
Dear litografa,
How to change the air as CO2, Nitrogen, argon?
Old 02-19-2011, 12:26 AM
My guess would be a welding supply store. You can get Argon and possibly nitrogen there. And usually they are a gas supplyer so CO2 would probably be something they carry. If not find a vendor for soda on tap, like resturants use. Those systems use very big tanks of CO2. Then it's just a matter of getting a regulator, and hooking it up where you air goes into the machine. Replace compressed air with the gas of your choice.
And on a more dangerous note I just read about a guy who uses compressed oxygen with a 250w laser to cut metal, the oxygen and laser vaporize the metal. Very intersting build. DIY CNC CO2 Laser Site
Old 02-19-2011, 02:03 AM
Litografa's Avatar
Fully agree with previous post, will try to find pictures from customer's laser who have replaced air with nitrogen - will post here.
Old 02-19-2011, 01:58 PM
brasil is on a distinguished road
Small trick to test - Humidity (water) and a spounge
I have already seen (years ago) in shoe factories the use of simple spounge and water to make the leather "humid" (?) before engraving/cutting.
After the laser engraving/cutting use the spounge again to clear the dirty that the smoke generated.
The cutting borders will still be burned, but with a more clean detail.
Old 02-20-2011, 09:13 PM
Hello everyone,
Many thanks for your replying.
There are so many interesting ways to deal with burned part on leather. We'll try them.
Thanks for your share with your rich experience.
Miss Echo
  #11   Ban this user!
Old 02-20-2011, 09:24 PM
What do you do?
Hello all friends,
What do you do?
You are all familiar with laser machine and learther processing state. We wander you are also manufacture, seller for laser machine? or you are using these machine?
Awaitting for your discussing.
Miss Echo
  #12   Ban this user!
Old 10-15-2011, 03:42 PM
gsm gsm is offline
gsm is on a distinguished road
Hello,
I read that text weeks ago. I was trying cut leather by co2 laser, with CO2 and nitrogen blowing (I replaced the pressed air).
My results are not successful. There is soot on the edges and surfaces. It is not acceptable for me - every cut shape is dirt. I'm thinkig about argon, because welders use it in processing. Disadvatange of the argon is that it is expensive and can be dangerous (processing in closed place).
Besides,
I wonder isn't it true. Nitrogen blowed on material does not protect before burning on black dirt(soot) material.
Maybe it always will be dirty after laser cutting and it is recomended to clean leather after processing? But how to clean it properly?
What do You think?
Need Help!- Can a laser cutting/engraving machine do leather embossing? artworldcn Laser Engraving & Cutting Machines 6 11-18-2010 09:54 PM
Cutting & engraving leather Dubliner Laser Engraving & Cutting Machines 6 10-26-2010 02:40 AM
help and advice needed - laser cutting leather geekinesis Laser Engraving & Cutting Machines 1 08-03-2010 03:56 AM
Laser cutting/engraving help. Glyn Jones Laser Engraving & Cutting Machines 5 02-02-2007 07:26 AM
Using laser for cutting and/or engraving wilfredtak RC Robotics & Autonomous Robots 15 09-24-2005 01:01 PM
