Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-08-2011, 07:22 PM
Jtron5 is on a distinguished road
Pass Through?
Any advice would be appreciated. My morntech 3050d has pass through doors, but in order to pass anything through the bed has to be lowered a bit and hence putting the beam out of focus. Am I overlooking something? Here is a tiny pic from the web.
[IMG] [/IMG]
Old 02-08-2011, 07:36 PM
lrob is on a distinguished road
Can you post a pic of your laser lens assembly.
Old 02-08-2011, 08:04 PM
Blackjax is on a distinguished road
this is the Morn MT-L960
Old 02-08-2011, 08:05 PM
Here it is...[IMG]
Old 02-08-2011, 08:10 PM
Hows that MornTech working for you? i have the large MT-L960 80w with all the options in transit to me as we speak and got it at a super price!
Old 02-08-2011, 08:15 PM
This looks very similiar to my laser. Mine has a set screw for removing the lens assembly. By loosening the set screw you should be able to raise and lower the lens and be able get the correct focus you need.
Larry
Old 02-08-2011, 08:16 PM
It's my first machine, and it has treated me right. I've read some horror stories about imported lasers, but this machine was ready to go on day one. I sometimes wish I had a larger bed, but 12 x 20 suits my needs most of the time. I would also kill for an an adobe illustrator plug in.
Old 02-08-2011, 08:18 PM
Thanks Larry. Which screw would you say, there is one which is barely visible behind the air hose, and a couple others.
Old 02-08-2011, 08:30 PM
That worked, thanks Larry. These machines don't always have the best support literature.
Old 02-09-2011, 08:25 AM
woodman08's Avatar
woodman08 is on a distinguished road
laser
you do not have a pass through access, all opening have to be closed before the laser will operate.There is talk of making a laser case with a small openning front and back no micro switches allowing a large object to pass through but has to be only 3/4 to 1 in thick
Also you should get or make a focus templateout of plexiglass then you loosen the fitting on the head and manually focus
  #11   Ban this user!
Old 02-09-2011, 08:41 AM
Litografa's Avatar
Litografa is on a distinguished road
Typical chinese mistake - have pass thru doors but forgot make them enough to move material in focus.
  #12   Ban this user!
Old 02-09-2011, 09:37 AM
woodman08's Avatar
pass through
with mine i think i could focus on 1/2 to 3/4 ,material if i had pass through(or cut it out my self)
Step over 2nd/3rd pass Sjotime DIY-CNC Router Table Machines 11 12-09-2010 12:30 AM
Problem- Bad pass ozstockman Wood Working Tooling 12 01-04-2010 01:32 AM
Need Help!- Each pass different than the previous gage1049 DIY-CNC Router Table Machines 4 10-22-2008 03:47 AM
Need Help!- cut depth per pass christ371 Dolphin CADCAM 3 07-19-2008 09:14 PM
Can I run axes at different ipm on the same pass? yorttroy DIY-CNC Router Table Machines 5 01-04-2006 12:34 PM
