| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hello all...I am new to this community and I have an interest in getting a laser cutter engraving machine to do some work on the side for myself at home. I have a large garage I could work out of but it is not well insulated and does not have a heat source. It is the ideal spot to work out of for me as it does have power...but I am concerned with freezing and extreme cold temps if I were to put a machine in there. On a side note I also have a small 10 x 14 wooden workshop/shed that is insulated which I could put a heat source in...but it does not have a power hookup and I dont intend to put one in. I was curious to know if a portable standby generator would be sufficient to run a machine...I was looking at a machine no larger then a logilase 9060 Specs: Power supply: AC 110 - 220V±10%, 50 - 60Hz * Gross power: <1,000W * Operating temperature: 0 - 45°C * Or anything going down from there in size...that might be a little bit big for me. I read another thread on here about use of generators and all I got out of it was that they probably would run desktop models but nothing further on larger units. Also that it would be wise to run throuhg a UPS to condition the power...my other concern is that these machines are obviously expensive I'd hate to void warranty to running off of generator power. Doesn anyone else have anything to add to this or any suggestions? Much appreciated! Thanks! |
| No this is not a good idea. you need clean and consistent power. Also, a temperature controlled room is ideal as too hot or too cold affect electronics, optics, etc...
__________________ www.FocusedLightEngraving.com sales@FocusedLightEngraving.com |
| Yeah thats what I was thinking....I dont want to gamble on it with a machine...I'm not gonna lie lol I was hoping I was going to hear a yay on this! Oh well back to drawing board and other alternatives! Thanks for the response! |
| Now this is not actual, but in 1990ies a lot of my customers in CIS countries run lasers with electric generators and UPS without any problems for long time. BUT I personally do not suggest to do this !!! And stability of temperature is VITAL. December 2010 was extremely difficult - changes in temperature, long holidays when customers switch off heating for long time and etc - was a lot of problems |
| I think it can be done, but you can't use your standard computer store UPS, you need to understand how UPS systems work. Your average desktop UPS goes from standby and switches on when it senses a power outage, this can cause a sag in power supply as it switches over. When using a generator this would be bad because the UPS doesn't filter the signal, you'll be powered directly off the gen, and the UPS will be charging off the gen at the same time. What you need is a Double-conversion / online UPS this one uses the batteries to condition the line and prevent spikes and sags in power. Also it doesn't have to switch on with a power loss, it's already on and just continues to proide power even without any power input. |
| Thanks for the replies! I am going to have to reconsider possibly moving my wooden shed maybe closer to my garage to get power off of it. I dont really want to trench all around my property to lay power out. I need to do more thinking/planning I suppose! Thansk guys! |
| Another thing to consider is insulating your garage, and heating it. I have a 14x20 shed I had that done to. I paid a guy to come insulate it, $300 including installation. Then I shopped around and found a used PTAC unit (hotel heater/AC unit) it cost me $50 and I'm going to install it for my heat and AC to the shop. |
| Need Help!- I am looking to buy a laser engraver/cutter | spookie91 | Laser Engraving & Cutting Machines | 9 | 11-15-2011 12:43 AM |
| New Machine Build- CNC Laser Cutter and Engraver | guy2b1 | General Electronics Discussion | 5 | 07-09-2011 10:34 AM |
| Need Help!- LASER ENGRAVER/CUTTER | gpenyy | Rockcliff Machine | 2 | 12-09-2010 09:30 PM |
| Why buy a Laser cutter when you can modify a laser engraver. | spacifique1 | Laser Engraving & Cutting Machines | 7 | 08-13-2007 02:39 PM |
