Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-30-2011, 09:00 PM
bpoulin is on a distinguished road
XYZ-Tech (Exlas) machines and my experience.
So far I'm extremely pleased with the whole process, Mike at XYZ-Tech has answered more questions than any CS person should have to lol. The shipment was uneventful but for all US customers be prepared to pay about $800 more for your shipments to clear customs. That has nothing to do with XYZ-Tech, but fees, and that you need to have 2 types of bonds on the import, and lots of other things, anyone who wants details, email me I'll send you a copy of my invoices so you can see in detail what US customs charges are. I would suggest if you are going to order multiple pieces of equipment, do it all at once to minimize your customs charges. I ordered 3 pieces of equipment. The Exlas 1280 Laser, 4040 CNC router engraver, and a 32" vinyl cutter.
My only regret is that I didn't get a larger CNC...
I had to unpack the crates and run and move out of my old house and into my new one. So photos are just the first of many. This is fresh out of the crate, and looks superb!!! Packing was awesome, looks like maybe bamboo sheeting with steel square tubing for the crate of the pallet. No noticible rust or damage from the trip. Doors open and close just fine. Tomorrow I will go through the electronics and check connections. Later this week, if nothing else goes wrong, I will have electrical done in the shop and will be able to fire these up for a test run by Friday. More info and photos to come tomorrow evening.
Workshop
Crate
Exlas 1280
Unwrapped 1280
XYZ-Tech 4040
Old 02-03-2011, 04:45 PM
Sorry for the long delay, moving is taking more time than it should.
220v 50/60Hz filter
DSCN0434 | Flickr - Photo Sharing!
Back Panel 220v input, air, water and USB cable.
DSCN0447 | Flickr - Photo Sharing!
Control Panel
DSCN0438 | Flickr - Photo Sharing!
Electrical panel 1
DSCN0437 | Flickr - Photo Sharing!
Electrical panel 2
DSCN0436 | Flickr - Photo Sharing!
I will post more after the camera charges back up.
Old 02-03-2011, 11:17 PM
GuiBerlin's Avatar
GuiBerlin is on a distinguished road
try it !!!
220v 50/60Hz filter
Control Panel
Electrical panel 1
Electrical panel 2
Old 02-03-2011, 11:24 PM
I can't wait to try it, but alas, the bad weather has put off running the wire from the meter to the shop. Saturday looks like a dry semi warm day. If we get the wire ran then, we can call the elect company Monday for a hookup time/day. Trust me the minute I have elect out there I will do something with it.
Old 02-03-2011, 11:38 PM
GuiBerlin's Avatar
I am sure you will :-)
(by the way, very nice pictures of that old farm on your Flickr account )
Old 02-16-2011, 11:36 PM
So I got power to the laser on sunday, and spent monday and tuesday (only a few hrs a day due to prior engagement.) setting up the software. Warning to others, Lasercut 5.3 isn't windows 7 friendly. It will work, Mike and Tony at XYZ helped me get through the install and driver install for the dongle. But it's not as simple as plug and play. The biggest hurdle I had was last night when I first tried to align the laser. I couldn't get it to fire. Mike walked me through a bunch of comon problems, and finally I found the problem, a plug on the power supply had wiggled loose in transit. After plugging it back in, no more problems! I spent this morning aligning the laser, that took about 2 hours by my self. It would have gone quicker with a helper. The machine was actually very close to aligned right out of the box, but I'm a perfectionist. I spent the rest of this afternoon burning random pieces of wood laying around the shop, and playing in Illustrator designing stuff. I'll post pics later, it's getting late tonight. I found a wonderful scroll pattern that I need to find a bigger piece of wood for. The design is too small for a 2.5" piece of scrap wood. Videos and Photos to follow tomorrow.
Old 03-06-2011, 08:51 PM
kiwisox is on a distinguished road
Exlas laser
Hi i am new here i also received the 1280 i got my machine shipped to New Zealand took a Few hours to get set up was not a problem couple of things to adjust but nothing major i had an issue with the laser tube with air bubbles appearing in the tube and causing it to crack got a replacement on the way
the must have started small and gathered into one big bubble causing a part of the tube to over heat and crack the laser cut 5.1 was easy to get going
just trying to fiqure out how to use the rotary attachment now my new tube should be here next week gonna try out engraving on all sorts of surfaces and will post pics and i also heard about windows 7 issues so i use and xp pc for running the machine was easy to do
Sox
Old 03-06-2011, 10:42 PM
Sox: I had to tilt the tube so the side closest to the power input was down and turn the chiller on and off until there were no bubbles on start up. That's when the bubbles break free. Then once the bubbles were all gone I re-aligned the laser and now I have a TINY bubble, aboout half the size of a pin head that is stuck, but that's the only bubble.
Old 04-26-2011, 09:56 PM
Exlas laser engraver
I got the new laser tubes machine is working nicley
i am having trouble with the rotary attachment i can engrave small objects
but once i go to a bigger object such as a bottle or glass
the words strech and i cannot find or work out how
to change the settings for using the rotary attachment i seen a post
where the settings where changed but i could not find it
in the laser cut 5.3 software
any help would be welcomed
Old 05-04-2011, 11:21 AM
kabli is on a distinguished road
Congratulation
Hi bpoulin
Congratulation on your EXLAS, I hope you will like this machine, we did order EXLAS 1280 one year ago, it is running perfectly nice, we do have another old EPLOG, believe me you can do allot with this machine , but you have to be careful with cooling the water.
a friend ask me to cut 80mg, paper as a business cards, I thought it will not be a good idea, I was wrong, it comes very nice cutting and clean, I put power as 10, and speed as 100.
i would like to add the photos, but i dont know how.
i add it in my facebook,
http://www.facebook.com/#!/profile.php?id=1226550125
i hope you can see it
if you need any help with your new machine, I would like to help, (in my free time)
bye
  #11   Ban this user!
Old 05-08-2011, 09:31 PM
EXLASer is on a distinguished road
business card cutting
Hi Kabli just show some pictures we made,
thick white card paper(thickness of a regular business card).Cut out the little squares and leave the grid behind.
The idea is to procuce cut quality as clean as clean and sharp as possible,with minimum burn mark.
16% power of 80w laser tube,speed200mm/s
mike
Originally Posted by kabli View Post
Hi bpoulin
Welcome to Facebook - Log In, Sign Up or Learn More
bye
ID:	133643   Click image for larger version
ID:	133644   Click image for larger version
ID:	133646   Click image for larger version
  #12   Ban this user!
Old 08-29-2011, 10:13 AM
diegope is on a distinguished road
So far so good with the exlas 1280?
Hi guys
I'm thinking of buying an exlas 1280. I'm curious to know how has your experience been so far.
All details welcome..
Thanks!
d.
Need Help!- HITACHI SEIKI MACHINES. SERVICE / TECH bob1112 General Metal Working Machines 6 09-14-2010 10:49 AM
New Machine Build- EXLAS purchase experience doug007 Laser Engraving & Cutting Machines 6 01-12-2010 04:25 PM
Experience with Colinbus machines? tingox Commercial CNC Wood Routers 9 04-03-2008 05:59 PM
Experience with Super Tech machines helix CNC Machining Centers 3 12-10-2004 02:17 AM
