Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-22-2011, 01:43 AM
echojdlaser's Avatar
echojdlaser is on a distinguished road
May we know your experience of Materials, Cutting Depth which Laser tube could do
Hello everyone,
Have a wanderful day.
May we know your experience of Materials, Max. cutting depth which laser tube do?
Such as,
Acrylic,
60W CO2 laser tube, cut max. 7 or 8mm
80W co2 laser tube, cut max. 15 or 16mm
180W co2 tube , could cut max. 30mm
Wood, leather, rubber, and so on,
May we know your idea?
Miss Echo
Chinese Manufacture, exporter for Laser Machine, CNC Router
Web:www.jdengraver.com Miss Echo: jd.market32@hotmail.com
Old 01-22-2011, 03:05 AM
Tweakie's Avatar
Tweakie is on a distinguished road
I cut 6mm acrylic with 30 watts.
I can cut up to 10mm but the sides start to show barreling using a 50mm FD lens.
Tweakie.
CNC is only limited by our imagination.
Old 01-24-2011, 02:25 AM
Acrylic cutting, and leather cutting
Yeah, the could try to test it by different laser power, speed.
We believe the machine will bring us miracel.
Before, we have tested 20mm acrylic cutting by 80W. It is a little barreling.
Do you have some idea on leather cutting? Tweakie. Some leather laser cutting, the edge of cutting area maybe black if cutting deeper? How do you deal with the black parts.
Regards
Echo
Tweakie.
Name:	cut 20mm.jpg‎
Old 01-24-2011, 04:50 AM
Tweakie's Avatar
Leather stinks.
The smell is so bad it lingers after the extraction system has been shut down so in my book leather and pvc are both no go areas.
Tweakie.
Old 01-24-2011, 07:51 PM
Do you have some idea on leather cutting depth ?
Have you tried 5mm hard leather cutting? which laser power you use?
Echo
Leather stinks.
Tweakie.
Newbie- Tips on laser cutting soft materials drmitsos Laser Engraving & Cutting Machines 4 06-12-2010 12:52 AM
Laser power vs. cutting depth data/rule of thumb adamchapman Laser Engraving & Cutting Machines 1 05-18-2010 11:55 AM
Newbie- Tube cutting; tin slots and tube ends marineboy CNC Plasma and Waterjet Machines 0 10-13-2009 04:03 PM
Need Help!- Laser with rotary for tube cutting PMF General Metal Working Machines 5 09-16-2009 12:57 PM
laser cutting tough, light, flexible sheet materials? vacpress Laser Engraving & Cutting Machines 4 01-11-2008 07:36 PM
