Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-21-2011, 07:59 PM
Dubliner is on a distinguished road
Cutting & raster engraving acrylic
I have to cut & raster engrave a few samples for a client. What would the recommended S&P be on a 100w co2 in 3/16 Acrylic for cutting and for rastering a small logo/trademark in the corner? TIA Neville
Old 01-21-2011, 09:24 PM
echojdlaser's Avatar
echojdlaser is on a distinguished road
Laser engraving cutting machine is little limited. It is good at for acrylic processing, when engraving, you could try fast speed, for cutting, maybe a bit slow.
80W could cut max. 15mm, 4mm or 5mm, 60W is ok.
You could try to test freely.
Echo
Chinese Manufacture, exporter for Laser Machine, CNC Router
Web:www.jdengraver.com Miss Echo: jd.market32@hotmail.com
Old 01-22-2011, 03:35 AM
Tweakie's Avatar
Tweakie is on a distinguished road
This was all done with 30 watts.
It's trial and error with the vector speed as it depends on material thickness as well as ambient temperature. Pretty much trial and error with the raster logo as well.
Tweakie.
CNC is only limited by our imagination.
Old 01-22-2011, 06:26 AM
grandpa jay is on a distinguished road
Do you have the dxf files for the three gears shown in the picture? I would love to try them on my CNC mill.
Grandpa Jay
Old 01-22-2011, 07:23 AM
Tweakie's Avatar
Grandpa Jay
Sorry, I do not produce a DXF because I run GCode.
I have attached the GCode for 1 gear - see if you can do anything with it. Because these were laser cut there is no Z commands but in the code I use B0 to turn the laser off (Z plus movement) and B1 to turn it on (Z minus movement). Search and replace could change these to Z movement. The included tool radius offset is 0.05mm (laser beam radius) so you would need to adjust your offset accordingly also all my units are metric.
It's a long shot but if you can do anything with it then email me and I will send the GCode for the others.
Tweakie.
Old 01-22-2011, 09:25 AM
zax15uk is on a distinguished road
Tweakie,
That's a really cool design!
I converted it to dxf and would love to cut the set and try it if you don't mind.
What program did you use to create these gears?
Zax.
Old 01-22-2011, 09:56 AM
Tweakie's Avatar
Hey Zax that's brilliant, I had not even considered the possibility of creating a DXF from the GCode. They were made using Gearotic Motion Gearotic Motion (written by Art of Mach3 fame).
Here are the other two.
Tweakie.
Old 01-22-2011, 01:49 PM
Hey guys - cutting is going well, but in one spot the cut went over some acrylic I was using as spacers under the sheet and the liquid acrylic seeped a littl bak onto the part, is there any way to clean that?, Its minor, but looks a little like when you used to put too much glue on the canopy of that Airfix Spitfire we all built as kids.
Old 01-22-2011, 02:06 PM
cellardoor7 is on a distinguished road
gear set
tweakie, cool gear set
zax, could you post the dxfs for the entire gearset?, i dont have means to convert from gcode to dxf. may i ask what software you use to do this?
thank you both
Old 01-22-2011, 03:24 PM
Here are gears 2 and 3 converted as is... so remember they have the 0.05mm offset. The same as gears1.
I also attached tweakie-gears.dxf that has all 3 gears without any offset (so you can apply whatever offset you want).
These were converted with ArtCAM, but I have several programs capable of this - DesKAM will do it, so will TurboCADCAM and I think you can use plugins with Google Sketchup and achieve it too.
Zax.
  #11   Ban this user!
Old 01-22-2011, 08:25 PM
thank you zax
  #12   Ban this user!
Old 01-23-2011, 01:59 AM
Tweakie's Avatar
I think the only way is to polish it out.
(the acrylic I use has a plastic peel off covering on both sides which does not ignite like the paper stuff so I cut it with the covering on - prevents this sort of problems but it's a pain to remove all the little bits from the finished parts still it's no worse than the vinyl sign weeding).
Brilliant work with the DXF's Zax, cant wait to see the gears.
Tweakie.
Raster engraving a vector drawing Dubliner Laser Engraving & Cutting Machines 4 12-06-2010 06:32 PM
The dynamics of raster engraving AustinT Laser Engraving & Cutting Machines 5 10-25-2010 11:13 AM
Acrylic engraving ARTILLERO General Material Machining Solutions 3 05-10-2010 06:11 PM
Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine stephaniehamer Laser Engraving & Cutting Machines 5 06-29-2009 03:37 PM
X2 Milling and engraving acrylic Jay C Videos 2 10-09-2008 11:47 PM
