Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 01-04-2011, 02:19 PM
cbc cbc is offline
cbc is on a distinguished road
Talking laser newbie
i just joined this site i do alot of work with lasers if i can help anyone i will be glad to
Old 01-05-2011, 03:18 AM
Tweakie's Avatar
Tweakie is on a distinguished road
Hi Cbc,
Welcome to the forum, some of us need plenty of help here.
This is an old chestnut but I am still having the occasional issue with horizontal 'banding'.
Everyone seems to have their own views on exactly what causes this effect and I am currently exploring mathematical rounding errors as the cause.
As a newcomer your views / suggestions would be more than welcome.
Tweakie.
CNC is only limited by our imagination.
Old 01-05-2011, 08:01 PM
bpoulin is on a distinguished road
NooB question, but what is horizontal banding? And do you have a close pic of it?
Old 01-06-2011, 01:52 AM
Tweakie's Avatar
It's one or more horizontal bands of different (incorrect ?) contrast. It is not so easy to notice close-up, it is more pronounced when viewed at a distance.
Tweakie.
Old 01-07-2011, 01:26 PM
cbc cbc is offline
horizontal banding reply
try slowing down the speed that ur machine moves front to back the slower it mowes the more passes ur laser will make over an existing path that ur engraving. i hope this helps
Old 01-08-2011, 01:46 AM
Tweakie's Avatar
Thanks for the suggestion but the horizontal paths are defined a Y steps and these are the same no matter what the horizontal speed.
Tweakie.
Old 01-08-2011, 09:34 AM
Huahahahahaha is on a distinguished road
I have problem when engraving big photo ( 90x60 cm)
i use Rabbit laser from china.
When i do that, it couldn't engraving all in one, must be separated to many files.
Reason:
1. not enough memory on machine
2. Lasercut program couldn't accept big photo.
After i did that with many files, it makes some gap between photo.
so it's have horizontal and vertical line between photo.
do you have solution for that?
Old 01-09-2011, 12:16 AM
cbc cbc is offline
Talking banding
when engraving photos the only thing i can think of is converting ur photo to black and white ,and then to a bitmap setting this fixes the banding but u will have to play with ur speed and power setting each maching is different.but u will have to invert colors this will make tiny dots and not banding if this does not help i will see what i can find out......
Old 01-09-2011, 12:32 AM
if just engraving one small photo smaller than 60x30cm, i already do that thousands time perfectly.
but when engraving big photo 60x90cm, it limited by machine memory and software capacity. so must be separated to more than 4 photo.
Then when combine that photo on machine, it always make tiny line on horizontal and vertical line between that photo, although i already make no gap between that photos
Need Help!- Newbie with New Laser and Problems YoungBlood Laser Engraving & Cutting Machines 13 09-08-2010 09:56 PM
Newbie to laser cutting Navop Laser Engraving & Cutting Machines 4 09-01-2010 08:31 AM
Newbie questions about laser choice.. Maru Laser Engraving & Cutting Machines 4 10-22-2008 12:18 PM
newbie for laser cutting googleman Laser Engraving & Cutting Machines 14 10-08-2007 07:16 AM
Laser newbie questions bgirit Laser Engraving & Cutting Machines 4 08-17-2007 11:18 PM
