| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi, I am currently undertaking the inertia calculations to determine the required stepper motor size, etc. My question is for a laser what is the range of speeds that I should allow for and therefore the required acceleration? I am currently building a 40w laser to start with, to get my understanding before I build a 150W. Thanks in advance |
| I assume you are taking all the factors into consideration in your calculations, for example belt, gear or screw drive. Microstepping. Axis length and weight. Planned use, cutting and/or engraving etc. 300ipm as a maximum velocity would be reasonable, and with a low mass design you can achieve this with some NEMA 17 or single stack 23 steppers and belt drive. I would probably go with the 23's and 1/8 microstepping for a small system. Zax. |
| I fully agree with Zax. My machine is a wood router with a laser head fitted as an optional tool. Unfortunately the mass of the X axis is such that my acceleration / deceleration settings have to be kept quite low and the maximum (100% reliable) travel speed is 3,500 mm/min. Although this is fine for what I want to do (mainly cutting acrylic) the machine would be a lot more versatile if I had 7,000 mm/min travel speed. My recommendation is to go for the highest speed you can reliably achieve without loosing steps etc. Also consider a servo drive (driven by similar 'step and direction' signals like the steppers) just for the X Axis. Tweakie.
__________________ CNC is only limited by our imagination. |
| speed vs acceleration. | ihavenofish | Benchtop Machines | 0 | 08-12-2009 05:57 AM |
| X2 CNC Conversion: Max speed and acceleration settings | Dr. DRE | Benchtop Machines | 9 | 10-08-2008 05:00 PM |
| Speed and feed calculations | Guldberg | Mini Lathe | 5 | 11-30-2006 09:58 PM |
| CNC Plasma Table Speed Calculations | Terry G | CNC Plasma and Waterjet Machines | 13 | 09-25-2006 02:03 AM |
| Looking for Speed/Feed calculations | scnolan14 | WoodWorking | 4 | 04-28-2006 09:46 AM |
