Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-27-2010, 07:52 PM
Pazzoom is on a distinguished road
Adapting a CNC router to laser engraver?
I have a good cnc but want to do some fine (as in small) engraving on wood parts. Similar to the kind of work done on pens. Not looking to buy into an entire laser machine setup.
What's involved in using a laser engraving head with my existing Shark Pro cnc?
Thanks.
Pazzoom/Jim
Old 12-28-2010, 08:29 AM
zax15uk is on a distinguished road
Do you want to burn the wood (pyrography) or engrave it (remove material)?
If you want to remove material to create a dimensional design then a CO2 laser is probably the best solution, but for burning you could use either a hot iron or diode laser.
The diode laser would be the easier to implement BUT I would suggest the hot iron as the easiest (just needs a spring loaded attachment).
The CO2 laser would provide the most options, cutting and deeper engraving but is the most expensive (~$600 for glass tube) and hardest to add to your system (mount flying optics or metal tube).
Zax.
Old 12-28-2010, 06:29 PM
dominicburke200 is on a distinguished road
see this website
see this Tweakie.CNC - CO2 Laser Cutting.
a good forum member from the uk called tweakie (i think) has done this to his cnc router he built. His build log contains lots of info. i've gone down the road of building two machines a router and a laser before i found that thread.
Old 12-29-2010, 06:45 AM
Originally Posted by zax15uk View Post
Do you want to burn the wood (pyrography) or engrave it (remove material)? ...
Zax.
Thanks, Zax. I want to remove material in the engraving process. So (naturally) the more expensive road will be mine. Thanks again for the handy tips. Much appreciated.
Pazzoom
Old 12-29-2010, 06:52 AM
Yes, a great source of help. I saw his very helpful information last night. And I will be reading through it more in the coming days. I used a laser in a workplace (many years ago) but never paid much attention to what was involved. Very helpful.
Thanks for the direction. I appreciate the help.
Pazzoom
Converting Shark Pro CNC router to laser engraver Pazzoom Engraving Machines 3 02-27-2012 09:58 AM
Garage sale!!! Save Big $$$$ laser engraver CNC Router, Vinyl plotter CNC automation Machinaria EBAY ADS 0 08-31-2010 07:30 AM
CNC Router LASER Engraver mod? woox CNCzone Club House 6 09-11-2008 01:18 PM
Your opinion on adapting my router collet MrBean DIY-CNC Router Table Machines 5 12-03-2004 11:02 AM
adapting a router to mini? JFettig Benchtop Machines 0 04-30-2004 06:51 PM
