Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-15-2010, 09:23 AM
Japazo is on a distinguished road
Mazak Turbo X48 Parameter Issue
Hello Everyone!
I am running a Mazak Turbo X48 1500 watt laser to cut everything from poly to stainless. The machine is dated but still functions well enough to use for most jobs.
My primary issue currently, is that the x-axis control doesn't seem to function the way it should when cutting rounds or diagonals. Any cut vertical or horizontal looks fine but rounds, diagonals curves come out with a slight (<.005") waviness to them. This also happens when stopping at a corner and traversing in the y direction, for about an inch to 1.5 inches.
The ball screws have been machined recently enough that the problem cannot be backlash. The servo/motor has been replaced and the problem persists so I assume it is a problem with the control aspect of the machine. The motor can be seen surging when the machine runs, indicating that it is not a hardware issue.
If anyone has any idea how I might go about solving this problem, please chime in and let me know! I would like to see this problem solved! Thank you ahead of time to anyone who contributes.
Old 12-26-2010, 07:50 PM
no ideas huh?
Tags
control, laser, mazak, parameter
Need Help!- 1990 Mazak LaserPath Turbo-X48 Mykal Ward Laser Engraving & Cutting Machines 4 04-22-2011 09:31 PM
Mazak Super Turbo-X 48 MKII Manuals sandmanxxl Mazak, Mitsubishi, Mazatrol 1 06-28-2010 10:49 AM
Need Help!- Okuma Howa 2SP 20H - Parameter issue davey242 Fanuc 1 03-02-2009 01:28 AM
Mazak M plus parameter? MrUZU1 General Metalwork Discussion 4 06-08-2007 08:50 PM
Mazak OP2 parameter xr135 Mazak, Mitsubishi, Mazatrol 0 05-17-2006 02:11 PM
