Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 12-08-2010, 06:22 AM
geekinesis is on a distinguished road
High voltage insulators
I am installing a new laser tube and want to make sure it is safe and doesnt arc etc. I have seen a few methods for insulating the red cable solder connection Including using a section of silicon tube as an insulator around the solder connection.
I have various 2 part silicon rubbers used for mould making etc. Can I use this to make an insulated sleeve around the solder joint? I understand silicon is a good uv insulator? I have reAd on the forum that people use silicon sealant.
I would use hv tape but it is hard to get hold of.
rabbit / ls3040
High voltage & high power servo drive design Xerxes Granite Devices 32 08-22-2008 09:24 PM
Why such high voltage? sp1nm0nkey Stepper Motors and Drives 19 12-31-2007 12:52 AM
high house voltage CASTLEVILLE General Electronics Discussion 3 12-04-2007 10:30 AM
High Voltage Drives Enteralterego Fanuc 4 08-15-2006 08:08 AM
PSU Voltage seems high. mnewsholme Hobbycnc (Products) 10 04-26-2005 03:26 AM
