Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-06-2010, 05:28 PM
srle76 is on a distinguished road
Red face help-ie300(iehk) laser engraver
just answer please.. it is posible to drive engraver with laptop??
i have usb-adapter..(trednet). lpt. ..but its seams that is not working .
yes or no..
or i must by desktop comp
thanx
Old 04-06-2010, 05:43 PM
DaveDoesIT is on a distinguished road
Yes, the laptop should do it fine. You should install the driver software to the laptop BEFORE plugging in the laser. If you have not installed the software first, then Windows will assign the best driver it thinks it should use and it will not be right.
You will probably need to uninstall that USB and then install the software and finally plug the laser in.
BE CAREFUL WHAT YOU REMOVE IN THE FOLLOWING INSTRUCTIONS
To uninstall the USB controller go to
Start
Control Panel
Device Manager
Universal Serial Bus controllers
Find the controller and remove it.
To uninstall the USB port assigned to it
Start
Control Panel
Printers
Select the printer driver for the laser and right-click.
Click the "Ports" tab and look down the list for...
USB: < whatever the laser is called >
Remove it.
Reboot and then load the software and after that plug the USB in.
Please make sure you know and understand what you are doing when removing stuff.
Dave
Old 04-06-2010, 05:52 PM
thanx
yessss
thanx for your time
Old 04-06-2010, 06:22 PM
zax15uk is on a distinguished road
Were you successful?
I would be surprised if this worked since the iehk300 uses direct parallel handshaking which is likely not supported with a USB-->Parallel adapter.
Zax.
Old 04-06-2010, 06:59 PM
not working
nothing ...uhh...must fix some old computer
Old 04-07-2010, 10:54 AM
not working
Sorry to hear that, but not unexpected.
Some of the parallel port units will work with a USB adapter, providing they use a standard Windows driver. In which case Dave's step by step guide will do the trick.
Zax.
Old 10-17-2011, 05:56 AM
Redjake is on a distinguished road
driver choice?
So what driver would you choose for the IE300 then?
cheers
Jake
Old 10-18-2011, 03:14 PM
bpoulin is on a distinguished road
I've never had good success with hooking up anything other than a printer up to a USB/parallel adapter. Sorry. You may be better off looking for a PCMCIA parallel card for your laptop. That is assuming you have a PCMCIA slot in your laptop. You can pick them up on ebay for about $15 including shipping.
wklaser(Gweike laser) new laser engraver display tina Product Announcements & Manufacturer News 2 09-21-2011 06:20 PM
New Machine Build- CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!! oliver9866 Engraving Machines 2 12-15-2010 02:44 PM
Need Help!- Instructions for IE300 series Laser McDuck Laser Engraving & Cutting Machines 5 07-15-2008 01:22 AM
Why buy a Laser cutter when you can modify a laser engraver. spacifique1 Laser Engraving & Cutting Machines 7 08-13-2007 02:39 PM
Need Help With IE300 Laser Engraver JWiggers Laser Engraving & Cutting Machines 13 03-03-2007 08:56 AM
