Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 04-02-2010, 11:30 AM
vsystems is on a distinguished road
Still trying to resolve a laser movement issue
I've posted before looking for advice on this problem, the one axis stutters and shakes when jogging or when running a job, after a process of elimination of power supply, drivers, and mechanical, it seems the problem is in the controller itself. It is a DSP controller, I'm wondering if this is anything anyone has seen before (axis sits still and vibrates when jog buttons pressed, but when it kicks to high speed it moves smoothly in one direction until it reaches the switch)
And if there is a way to repair this, or if I should look at a replacement controller, and if so, what replacement? Since it's DSP and has an LCD control panel/buttons, what would be able to replace it?
tia.
Update: I've pulled the motion controller, it appears to be a mpc6515
Old 04-02-2010, 11:55 AM
SkipW is on a distinguished road
Just a thought...
Have you tried raising the slow jog speed a little in the software? Like if it is set to 6, raise it to 8 or 10 and see if that does anything?
If it is a controller issue it probably won't make any difference but there's a chance it could be a work around.
Old 04-02-2010, 12:45 PM
DaveDoesIT is on a distinguished road
I assume you have swapped the drive cables over to make sure that the problem stays with that axis.
Are they steppers, open or closed system? If closed or servos try swapping over the encoders. Check the encoder connections.
How many components are there on the board that can be swapped around? As in ICs in sockets? Swap one thing at a time and test until the problem changes.
Often you can piggyback a new chip over an in-circuit one. Can be a risky thing to do though as it may Pffhht something else. In a pure logic circuit it should be OK, but do not hold me to that. Your RISK entirely. Turn the power off and let it set for 1 minute or so before piggy backing if you do it. make sure you have the IC the correct way around. Ground and power may be swapped and jittering may suddenly be the least of the problems.
If you have one good axis then use a scope and digital probe to compare waveforms and state at various points between the two axis. Find where it suddenly goes haywire on the problem axis.
It is virtually impossible to tell you what can be done without being in front of the thing and a schematic in hand. You just have to be as rigidly analytical as possible.
Dave
Old 04-02-2010, 12:55 PM
Originally Posted by SkipW View Post
Just a thought...
The only controls that I have access to are the control panel ones, there are no further software controls that I can tinker with since it's not mach3 or anything good.
Old 04-02-2010, 12:59 PM
So far I've replaced the stepper drivers completely, no dice there, I tested all the power supply outs which all were good, tested everything I have access to up to the MPC6515 board. I've read that these frequently experience firmware corruption? So I'm in the process of tracking down and installing the latest available firmware. Strange thing is that the board is stickered with v4.1.2.0 and no trace on leetro's site for anything higher than 4.1.1.0.
I've seen some forum posts mentioning 4.1.3.0 but google isn't helping me.
Old 04-02-2010, 01:00 PM
Dave
Was going to try this if the firmware thing doesn't pan out. I'll keep ya posted.
Old 04-02-2010, 01:34 PM
Did you try swapping the motors and see if it follows the motor or the axis.
I would not worry about stickers.
If it was firmware it would be on both axis. I would not have different firmware for each axis movement.
You need to be one-step-at-a-time analytical here.
Dave
Old 04-02-2010, 01:42 PM
It doesn't use LaserCut software? My mpc6515 card is ver. 4.0.0.15 and the jog speeds are adjustable in the LC software. That probably wouldn't help you anyhow. Unfortunately I don't have the electronics knowledge that Dave or Zax or some of the other posters here have, so that was all I could come up with.
I was just curious if changing the slow jog speed would have any effect on the problem. Apparently there is a bug in my LC 5.0 and controller combo that prevented me from being able to jog the head at all after I unchecked the "auto datum" feature in the software. I had to change the slow jog speed in the software to 8, then it worked again.
I'm sure that has been corrected in later versions.
Hope you get it fixed.
Skip
Old 04-02-2010, 02:02 PM
I did switch the motors, and the problem followed to the other motor, so it's not the motor. I did the firmware update and it did to SOMETHING, it removed the slow jog speed from the control panel and now any jog press is full speed, however this still does not solve the problem. That's when i switched the drivers and even with the new drivers in place, the problem still existed. So what am I missing between the drivers and the MPC6515 that's causing the problem?
I just did another test and swapping the pulse cables that go to each of the drivers not only reversed the motors (i.e. up = left, down=right on the control panel) which is to be expected, but it also made the problem follow to the other axis. So I checked the mpc board again, there were two identical ICs in sockets on the board, I switched them around, that didn't make any difference. So again, I'm somewhere between the mpc and the drivers. Perhaps I'm wrong about the power supply? I just don't know enough about how this thing is wired.
Old 04-02-2010, 03:17 PM
I will be surprised if it is the power supplies. Did you try swapping those leads to the controllers?
Well you are narrowing it down. If swapping the two ICs changed nothing then it is beyond them and before the pulse cables. Time for that scope and digital probe.
have you swapped those pulse cables over?
Have you examined the solder joints on the boards (top and bottom) with a magnifying glass?
Just keep trying the swaps until you have eliminated everything that is swappable. Then it is time to start comparing signal stuff.
What about a couple fo pics showing the two ICs you swapped and all the way to the pulse cables. It is really hard trying to diagnose this without any idea of what I am looking at.
Don't bother with trying to think what might be wrong. At this point it is now down to hard signal testing.
Dave
  #11   Ban this user!
Old 04-02-2010, 06:34 PM
Well I've switched the power cables that are going into the drivers, no change there, and since the problem followed witch whichever plug was on the Up/down (Y) axis no matter how I switched the plugs, I believe you're correct it has to be something to do with the pulse/direction wires that are going into the drivers. as I understand it the UVW wires are to the motor, correct?
I'm currently without a cable for my camera, so I can't get any decent pictures with my phone. But the wires are so tightly wound and wrapped into spinal-cord type bundles with no markings, it's very hard to trace them so I'm doing continuity tests now.
  #12   Ban this user!
Old 04-02-2010, 07:18 PM
zax15uk is on a distinguished road
From the testing you've already done, it sounds like the problem could be with the cable between the driver and motor.
Zax.
Need Help!- G02 but X Y Z movement PEU G-Code Programing 5 02-18-2010 05:06 PM
movement varies barnesy Machines running Mach Software 1 05-26-2008 11:47 PM
how to control laser head movement from PC nicklv Laser Engraving & Cutting Machines 2 03-01-2007 08:40 PM
No Movement wishmasterg Mach Mill 3 02-14-2007 06:39 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
