| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
I need to cut .001 to .005 in. thick stainless foil to make parts about 1 in. square and wondered if there was a cheap laser (<3k$) that could do the job. It can run slow since these are prototype parts. I can build my own system if need be since I have I have x y tables and motion control hw on hand. I read that the cheap Chinese 80w CO2 laser tubes will not cut metal, but is that true even for thin foil? Are there any other sources of non CO2 lasers in my proce range that that would cut foil? Thanks in advance for your help. Doug Atlanta, GA |
| Doug, Yes, sorry but that is true even for thin foil. The wavelength is just not suitable. What you need is a low cost Nd:YAG or Yb:YAG fiber laser, look for a surplus medical laser or buy a pump diode and make your own. Zax. |
| I searched ebay for yag lasers and noticed lots of small cheap ones for tatoo removal. The plse rate only goes up to 5hz, so I guess that's too slow, but do you think they might work. Laser type Q-swiched Nd:YAG wavelength 1064nm/532nm Pulse Energy 400mJ~1100mJ Pulse Duration ~10ns Pulse rate 1,2,3,4,5Hz http://cgi.ebay.com/PRO-Q-SWITCH-YAG...item3efe0aed4b Thanks, Doug |
| Doug, 10ns pulse duration at 5kHz, with a maximum power of 1.1J (that's if it can even deliver max power at max duty cycle - maybe not) isn't even close to the power you need. Look for a Ytterbium laser (marking system) on the surplus equipment sites, they come up now and again within your budget and worst case you'll have to drop a couple hundred bucks on a new pump diode. Zax. |
| Would this laser IPG 100w DLR-100-AT I see on ebay be a better choice and able to cut the .005" stainless steel foil? http://cgi.ebay.com/NEW-IPG-Photonic...item27afe52226 Thanks for the advice. Doug |
| A quick google search brought up their website and a pdf with the specs. Here is a link: http://www.ipgphotonics.com/Collater...DLR_Series.pdf It's not a metal cutter either.
| Zax. |
| Google YAG, saw http://www.tradevv.com/chinasupplier...r-cutting.html It applicable various metals, alloy and so on. Is that you want? But YAG seems not cheap. |
| A CO2 laser can be made to cut metal but at huge power ratings, starting in the 2,000Watt range and prices start around $200K. Currently there are no cheap YAG lasers as they are not as popular as the CO2. Today a "cheap" used YAG starts around $20K, if you are lucky. What are you trying to do? How many parts do you need to cut? How big is the part? There are better ways. |
#10
Doug, All these guys have given you the right answer. You need YAG or KiloWatt CO2 to cut metal. Pulsed YAG cost $40K+, and Kilowatt CO2 cost $250K+. The IPG laser you looked at will not work, you need pulsed YAG. If you only need to cut several pieces, I can manage to get it done for you free of charge. 0.001 - 0.005 is not a problem, I have cut 0.070 stainless steel with our small 20Watt YAG Laser. Peter |
#11
| Hi, Doug, A yag50w laser or a 10w fiber laser can do that work. Fiber laser can have more good cutting effect. We also have co2 laser, 60w,80w,100w, we can do some test on our machine. You can inform me your material details if you like. kind regards, Ms.June Zhu www.zhongtailaser.com june@whzt.com mobile:86 18607188502 |
| Marking Stainless using CO2 laser 60 Watt | Huahahahahaha | Laser Engraving & Cutting Machines | 21 | 11-05-2010 08:10 PM |
| Need Help!- Laser suitable to engrave stainless steel? | el_tony33 | Laser Engraving & Cutting Machines | 20 | 01-20-2010 06:45 AM |
| RFQ laser cutting 22GA stainless. | nate | Employment Opportunity | 1 | 04-09-2009 11:10 PM |
| what is the Best Laser cutters up to £15,000 for cutting stainless steel? | Paul Shroom | Laser Engraving & Cutting Machines | 1 | 03-24-2009 09:17 AM |
| Laser Cutting Stainless Steel ??? | Babba | Laser Engraving & Cutting Machines | 21 | 03-24-2008 06:48 PM |
