Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-17-2010, 03:22 AM
GP2482 is on a distinguished road
Honeycomb Beds - Where can I find them.
Hi All
First off, great forum and learning heaps. Thanks in advance for your help.
We've got a 36EXT Epilog laser (600mm x 900mm bed) and need to replace the honeycomb beds. Pricing from the reseller here in Western Australia is exorbitant to say the least - $935.00.
Does anyone know of an accessory supplier in the market that can make these to spec etc??
Cheers
Gavin
Old 03-17-2010, 09:40 AM
zax15uk is on a distinguished road
Gavin, I don't know a supplier in Oz but try your local specialized metal supplier. It's a standard product they should be able to order for you.
I got mine for slightly less than $30 USD (300mm x 300mm) so you should be able to find it for under $200 to fit your bed.
Zax.
Old 03-19-2010, 11:44 AM
buc buc is offline
buc is on a distinguished road
Hello,
in case you drop by soon in italy:
www.celcomponents.com
Cherio,
buc
Old 03-26-2010, 09:42 AM
KPBadger is on a distinguished road
Hello
Another option is aluminium 'eggcrate' grille - as used for HVAC industry.
the suppliers can make it up to size with the appropriate edging angles etc.
with either material you could go wild and get it black anodised at a metal finishing shop .
theory is that it reduces beam reflections though to be honest i dont know how much benefit 'actually' derives from the anodising. - it certainly looks pretty good!
regards
KPB
Old 03-26-2010, 02:27 PM
Litografa's Avatar
Litografa is on a distinguished road
Wait 2-3 weeks - I will have BOMB in honeycomb table engineering
Final tests are in progress
Old 04-22-2010, 09:43 AM
Litografa's Avatar
First bomb was exploded
http://www.litografa.lt/index.php?aid=357
Here is information about our vaccum tables for lasers.
Tomorrow I will place here information about our pin tables for laser cutting (need some time to finish with pictures)
Old 04-28-2010, 06:14 AM
Litografa's Avatar
And finally pin tables are available now
http://www.litografa.lt/index.php?aid=360
Good Source of Honeycomb FlyGuy007 Laser Engraving & Cutting Machines 0 03-14-2009 10:31 AM
honeycomb table material? bgirit Laser Engraving & Cutting Machines 5 12-25-2008 08:25 PM
Source for Aluminium Honeycomb? buildsomething Laser Engraving & Cutting Machines 8 11-05-2007 06:53 AM
cnc slant beds 65-295 General Metal Working Machines 1 08-14-2007 11:43 AM
where do you guys buy your honeycomb? sloppie Laser Engraving & Cutting Machines 4 02-10-2007 12:29 PM
