Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 03-11-2010, 03:10 AM
aaronseymour is on a distinguished road
How to Maximise Burnt Edges?
Hi. Oddly enough, for a project I'm doing I want to maximise the singed edge effect on the laser cuts I'm doing through paper. Does anyone have any advice on how to do this? I'd like to get as blackened an edge as possible (rather than the classic whispy brown). Perhaps different types of paper might make a difference?
Any clues very welcome!
Old 03-11-2010, 03:37 AM
KPBadger is on a distinguished road
blackened edges.
hello
yes it does sound bizarre to 'want' to achieve this!
you could -
- of course choose paper which blackens worse than other ( i find the grey shirt-card type stuff can be really bad )
- defocus to get a wider spot size.
- cut slower on lower power
- make an offset copy(s) of your cutting boundary to the inside and cut these lines at lower power - just enought to scorch. you could make this inside line a 'rough' line - by various software means.
OR - how about just cut your parts as normal and then drag them through a flame until the desired effect is obtained ! like how we made 'treasure maps' as kids.
good luck!
Old 03-11-2010, 07:55 PM
Thanks for the reply. Appreciate your generosity.
Old 03-12-2010, 08:24 AM
zax15uk is on a distinguished road
If you de-focus the beam it will cause more burning but not the charcoal edge that you want, and is more likely to cause a fire. You will also lose the ability to do any fine detail.
I would recommend using a slower speed and increasing the air assist to prevent flames, you may need to reduce the power slightly too.
The offset method KP suggested would work well too.
Zax.
Tags
burning, burnt, singed
CNC On A Budget - Burnt! Rhodan CNCzone Club House 14 01-18-2011 12:55 AM
trying to get my milling machine working burnt compacitor hmcl281 General Metal Working Machines 3 12-06-2007 12:47 PM
Burnt out motor and gecko 201 ??? 2fst4u CNC Plasma and Waterjet Machines 4 05-01-2007 09:19 AM
Rounding edges with bobcad jrc347 BobCad-Cam 5 06-16-2005 09:44 PM
Rookie needs help(How To Round Edges) mutionu General Metal Working Machines 8 01-06-2005 08:11 PM
