| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
Hi from France! I have a Mercury LaserPro 1548 engraver with a Synrad 48-2 25 watt laser. There is no beam from the laser though power is supplied OK - the green LED is on - and the red laser LED pulses when a signal is fed to the machine which seems to indicate the the PWM signal is being processed OK. So, I think the problem is within the laser itself. Are there any serviceable or replaceable internal parts (like transistors) inside? Are they accessible? I can't afford to send it back to Synrad and I'm hoping it's not a regassing issue - though that seems unlikely as there is no beam at all. Hope somebody can help or advise! |
| The laser dates from 1999 but hasn't done a lot of work. It definitely only has 2 LED's on the end of the laser (there is a remote one marked "laser" on the control panel which does not light). It's an OEM model so there is no keyswitch and the sub D socket has the standard blanking plug with internal links. I am doing some further electrical checks and will post the results if they reveal anything. Thanks to all! |
| Hi I am Synrad lasers serviceman. If you are interested to repaire or diagnose your laser send me a massage. Wojciech Bialek cinematic2@o2.pl |
__________________ We are a factory from China, nice to discuss the CNC with everyone!! www.jxcncrouter.com |
| Sounds to me like an internal problem as the red LED pulses to indicate a TTL signal and correct 30Vdc supply. If all else fails and only then.......... There are many c'sk cap head screws to remove from the bottom cover of the tube, inside inspect the two RF circuit boards looking for blackness or discolouration around the power transistors (there are one or two power transistors on each board depending on the age or model you have) as this is the most common failure. The RF power transistors can be replaced and if necessary the board repaired (all signs of conductive carbon must be removed etc) but observe extreme care when disconnecting the output capacitor from the tube risers (no strain or excess movement of the risers is allowed). Contact me if you need more details. Tweakie.
__________________ CNC is only limited by our imagination. |
| Tags |
| 25 watt, no beam, synrad |
| Synrad 50 watt laser | KTP | Laser Engraving & Cutting Machines | 26 | 11-11-2011 02:38 AM |
| Please HELP! Synrad control | zoltan | Laser Engraving & Cutting Machines | 21 | 07-06-2011 02:22 PM |
| Synrad Vs GSI | MisterP | Laser Engraving & Cutting Machines | 1 | 04-28-2009 12:31 PM |
| Need Help!- How align IR beam (co2) with visible beam (red dot laser) ? | etienne delcuve | Laser Engraving & Cutting Machines | 7 | 02-04-2009 05:41 AM |
| Short beam/Long beam? - Basic design | Pat2000 | Mechanical Calculations/Engineering Design | 5 | 11-09-2005 10:49 PM |
