| Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here! |
i am going thru a prob with chiller unit . today when i started laser machine to cut vector , laser stoped inbetween the cut. i dont know exactly, may be i on the chiller and directly i started cutting. but when i opened the chiller and checked i found compressor part geting hot too much .. but later it was ok, the laser started cutting. wht i want to know is this normal for laser chiller..is there any thing to be done to avoid these prob? |
| Hello, When you post question, please provide detailed information about equipment - laser model, power, type of tube, picture of cooling system, indication of temperature on cooler display when problem was happened. Sudden stop could be connected with high temperature of water inside cooling system. On most Chinese laser systems laser switch off when water in cooling system is over 25-27-30 degrees Centigrade. BUT this is only one of possible reasons. |
| Be careful, such problems on this tube could bring you to MUCH BIGGER PROBLEMS ![]() First of all check your cooler - change cooling liquid, if possible clean all pipes. If laser under warranty - call service and arrange their visit. My suggestion to you do not continue work if it will happened once more. Your tube cost over $20 000 and overheating is very dangerous for Rofin. |
| I USED TO PUT COOLING AGENT FOR CHILLER (DISTILLED WATER ) BUT I TRIED CHILLED WATER IN THE TANK, I TRIED TO UPLOAD PHOTOS TO THIS MESS , BUT SHOWING UPLOAD FAILED MESS, THE FILE SIZE IS LESS THAN 500 KB, I DNT KNOW WHATS THE PROB.. BUT LET ME TRY.. |
