Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-27-2010, 05:21 PM
Propaganda's Avatar
Propaganda is on a distinguished road
Power needed for 1/4" plexiglas?
How much wattage is needed for cutting 1/4" plexiglas/acrylic cast/extruded?
"The whole world must learn of our peaceful ways... by force!" - Bender Bending Rodríguez
Old 02-28-2010, 02:45 AM
Litografa's Avatar
Litografa is on a distinguished road
Minimum 25 Wt, optimal 40-60 Wt for aluminium tube. Double digits for glass tube.
Old 02-28-2010, 06:50 PM
LaserImage is on a distinguished road
I have a 30 watt and it cuts it just fine. Might be a bit faster on a more powerful machine, but that's not always the case.
Old 02-28-2010, 07:05 PM
Bryden is on a distinguished road
We have been doing some trails on our 2 and a half kilowatt Amada, we've only cut thinner stuff but I just wanted to add that using low pressure oxygen for assist gas you can get a very clean finish on the cut edge, using clear acrylic the cut edge is clear as well
Old 03-02-2010, 09:20 PM
Propaganda's Avatar
Double digits for a glass tube, eh? About where I guesstimated.
Thanks for the replies.
Old 03-05-2010, 07:14 PM
laserengraver is on a distinguished road
Smile power using on acrylic cutting
80w CO2 glass tube, you can use power 90. speed 15
60w CO2 glass tube, you can use power 90. speed 8-10
JENNY
www.wklaser.com
JENNY at wklaser.com
www.wklaser.com
What are some ways of storing "sun energy" that would be useful for power generation? Smertrios Environmental & Alternate Energy 40 12-14-2009 11:56 PM
"Astrosyn Miniangle Stepper" Power Drive hferraz Stepper Motors and Drives 0 10-31-2007 03:27 PM
Power needed to cut 1/16" ABS and 1/8" Acrylic? SRT Mike Laser Engraving & Cutting Machines 1 10-18-2007 10:24 PM
Home Made "Junk Box" Power Supply emtffkev General Electronics Discussion 11 04-20-2007 07:11 AM
Macro to read machine "power on" jakk100 G-Code Programing 9 04-12-2007 09:15 AM
