Go Back   CNCzone.com-The Largest Machinist Community on the net! > Other Machines > Laser Engraving & Cutting Machines
Laser Engraving & Cutting Machines Discuss CNC Laser cutting machines here!
Old 02-27-2010, 11:56 AM
TheWorkshopGuy is on a distinguished road
No more "Laser Beam"
Today while I was using my LG900 the Laser Beam quit working.???
I have checked inside of the machine and the "Power Supply" does not seem to be running anymore? The fan has stopped.
I am assuming it is the Power Supply that has failed and not the Laser tube.
Any help or suggestions would be appreciated.
Thank you
David Bethune
Old 02-27-2010, 03:38 PM
I removed the power supply and it had a very badly burned transistor inside of it. So..my problem is solved, now I have to order a new one. Hopefully it is under warranty I've only had the machine since November 2009.
Any reps from G. Weike on here? Please respond if you read this message.
David
Old 03-01-2010, 12:32 PM
Pplug's Avatar
Pplug is on a distinguished road
Try replacing the transistor, it would be cheaper. what are the numbers on it?
Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3
Old 03-01-2010, 12:34 PM
Pplug's Avatar
DP
Old 03-01-2010, 02:39 PM
HI
The transistor was vaporized. I have no idea what it was..
Old 03-09-2010, 08:21 PM
tina is on a distinguished road
David
hi workshopguy,if you remember which person you contact of gweike laser?
you can contact her or him by mail,and tell your problem,she or he will be very glad to help you.
check your mail,and contact her or him
our manager's mail address is wklaser@hotmail.com
Looking to buy CO2 Laser Cutter from China "Pros v Cons" Recommendations Joe001 Want To Buy...Need help! 4 01-21-2010 08:39 PM
Introducing the "Xaser"- Low cost laser marking mill/router add-on XaserSystems Product Announcements & Manufacturer News 67 11-01-2008 08:27 PM
Problem- Laser fires on "Laser Test", but not from software SimonArthur Laser Engraving & Cutting Machines 6 06-18-2008 02:32 PM
"DAVID" Free 3D Laser Scan Software! Switcher Digitizing and Laser Digitizing 1 01-26-2007 03:42 PM
Helical Beam coupling vs "lovejoy" type? phantomcow2 Linear and Rotary Motion 4 10-07-2005 05:52 PM
