I'm not sure why you would want to do that, unless you are concerned with the spot size of the larger tube. If so, just swapping the lens would probably yield acceptable results.
If there is something other than the spot size that I am missing, you could get a dual 60W system with integrator and either run one (why?) or both at a reduced power.
Zax.
LinkBack URL
About LinkBacks
