What material should I use to build a 450nm optical protective box?
Results 1 to 3 of 3
Thread: What material should I use to build a 450nm optical protective box?
    Dec 2016
    Portugal
    Question What material should I use to build a 450nm optical protective box?
    Hello there!
    Im building a laser graving machine from a former 3D printer, and have decided to buy this head to start my quest.
    The problem Im having now is that the machine will be in a rather busy place, where lots of people walk by all the time. So, a simple pair of protective gogles wont do the trick, as I wont be the only one needing protection.
    Is there a kind of acrylic protective glass I can build a box from? I cant find it in any DIY forums. Is it really necessary to have such protection when using a 500mW laser?
    Thanks in advance for any answers.
    Best regards,
    Afonso Urbano
    Oct 2008
    Portugal
    Default Re: What material should I use to build a 450nm optical protective box?
    Not cheap... But yes... There are a few materials for that.
    Here is a good start : https://www.lasersafetyindustries.co...ers_s/1356.htm
    Member Iron-Man's Avatar
    Jan 2009
    Quote Originally Posted by afonsurbano View Post
    Hello there!
    Best regards,
    Afonso Urbano
    Try this: https://jtechphotonics.com/?product=...aser-shielding
    You may also be able to find larger sheets.
    Hope this helps,
    Iron-Man
    Attached Thumbnails Attached Thumbnails What material should I use to build a 450nm optical protective box?-445nm-laser-shielding-measurement-500x500-jpg
