Using a lense to selectively alter the cutting beam profile
Results 1 to 2 of 2
Thread: Using a lense to selectively alter the cutting beam profile
    Sep 2016
    Default Using a lense to selectively alter the cutting beam profile
    A friend of mine is experimenting with one of the inexpensive Chinese laser cutters, the beam of which passes through a lense that focuses the beam to a point.
    We'd like to convert the beam of that cutter from a converging beam to a parallel beam at a selectable point.
    Information found on the net indicates that placing a cylindrical lense in the beam path will alter a converging beam to a parallel beam as we'd like but we don't know enough about lenses to know we correctly understand this solution.
    We've found a "25mm focal length cylindrical lense" on eBay -New Edmund Optics Cylindrical Lens 12 5mm Dia 25mm FL BK7 P N 46194 | eBay - but we don't know what a "25mm focal length" is in such an lense, or if the lense we found would suit our purpose.
    Any thoughts would be greatly appreciated.
    TIA
    Oct 2008
    Portugal
    Are you trying to do a light-saber?
    .. the lens you are talking about are something like this.. no? (Attached file)
    Quote Originally Posted by jeb6319 View Post
    TIA
    Attached Thumbnails Attached Thumbnails Using a lense to selectively alter the cutting beam profile-considerations-using-cylinder-lenses-fig-5-png
