- Gantry stepper only needs 1.2kgf/cm of torque?
I've done some homework on stepper sizing for my laser build.
In brief for single axis mounted on gantry:
Weight of moving parts roughly 500gm. (used 700gm in calcs)
Stepper drive pulley (GT2, 20 teeth, approx 13mm diameter) direct to linear belt. No other ratio adjustments
Axis travel on 2 x parallel 12mm round guides with 70mm long linear bearings
Expected feedrate 600mm/s at 0.1sec acceleration and deceleration.
I thought I would be pushing the limit for a Nema17.
Plugged my data into an online calculator: Belt Actuator Sizing Tool
Long story short, the estimate is showing 0.12...... N/m of torque. If conversion is correct this should be roughly 1.2kgf/cm? Maybe I haven't used a large enough friction coefficient or something.
But I was expecting to need a higher torque stepper based on some very rough calculations a few weeks ago.
Does this sound reasonable? Or will a stepper capable of 1.2kgf/cm be insufficient?
Thanks in advance for any advice
- You may not post replies
- You may not edit your posts
Forum Rules
