- Chinese co2 50w Laser machine will not cut - PRoblem
Hi all,
I'm looking for help and/or support with an issue that I have just encountered.
Problem:
Last week whilst cutting some poplar wood, I heard a high pitched squealing from near the laser tube. I immediately stopped the machine to inspect it. Seeing no obvious sign of a fault, I powered the machine up again and tried a pulse test. All seemed fine and I managed to cut something.
I then left the machine and forgot about it. A day or two later, I tried to cut something again and nothing! The machine powers up, the XY axis moves fine as does the control panel as well as the water and air pumps. The actual laser tube looks in good visible condition with no signs of cracks etc. and does not emit a pink visible beam.
My questions are:
1. Does this sound like a fault with the actual laser tube problem or hardware? I'm personally leaning towards a tube issue as the rest of the machine seems to be in order.
2. If there a troubleshoot guide or does anyone have any fault finding advice?
Thank you all for taking the time to read this post and I would be most grateful for any advice and/or help on my problem.
Thanks again,
James
- You may not post replies
- You may not edit your posts
Forum Rules
