Laser tube works on frame drawing and works while moving the head.
Results 1 to 2 of 2
Thread: Laser tube works on frame drawing and works while moving the head.
    Feb 2017
    France
    Question Laser tube works on frame drawing and works while moving the head.
    Hello guys!
    Im using standard China blue-white laser cutter 50wt
    The story: few days ago my laser got stuck firing at one point right in the middle of work, and after restart I have found that tube gone dead (on pulse test - no light inside and lightnings from cathode).
    Received a new tube, added ammeter (LensDigital - How to add ammeter to 50W Chinese laser cutter from eBay) and got
    THIS ISSUE: laser continues firing while moving from one drawing line to another.
    Pressing the "Frame" button gives a very weak laser too, so now the frame is literally drawn on plywood.
    Check these images please:
    You can clearly see that laser works continuously even at moments where it must be turned off.
    Please give me an advise what this could be?
    How to fix this, or what should I replace?
    Thanks in advance.
    Attached Thumbnails Attached Thumbnails Laser tube works on frame drawing and works while moving the head.-img_1896-jpg   Laser tube works on frame drawing and works while moving the head.-img_1894-jpg   Laser tube works on frame drawing and works while moving the head.-_57-jpg
    Feb 2017
    France
    Default Re: Laser tube works on frame drawing and works while moving the head.
    ISSUE SOLVED by changing power supply.
