- laser cutting head / acryl glas up to 10mm
Hi
I want to replace my Spindel on my privat 3 Axis CNC by a laser cutter to cut several Materials:
- Main use several type of Acrylic Glas up to 10mm
- different type of Wood
- Aluminium Up to 3mm (if possible)
Due main use to cut acrylic glas I am searching a cutter that cuts in an right angle as much possible and not spreads off conically to much on outlet of material (downside)
I don`t want to use laser tubes, I would have to modified my CNC heavely, and prefer to spend more on buying a laser head ( like Spindel) to plug and Play it.
Does somebody give me a hunt, and expirience values of type, power, having more expirience then I do to define the right and affordable Laser cutter? perhaps a chinese cutter?
thanks guys and wishes
F
- You may not post replies
- You may not edit your posts
Forum Rules
