NEED HELP! Chinese 60w Laser cutter won´t turn on.
Results 1 to 6 of 6
Thread: NEED HELP! Chinese 60w Laser cutter won´t turn on.
    Jul 2016
    Venezuela
    Post NEED HELP! Chinese 60w Laser cutter won´t turn on.
    Hello everyone, I am a newbie in the forum and in laser cutting as well.
    I recently bought in Amazon a 60w Chinese laser cutting machine with a working area of 500x700mm. It worked properly for the first non continuous 4 hours. Yesterday I was cutting some pieces and after 30min working it suddenly turned off.
    I checked the emergency stop button and it was on the correct position.
    Checked that the power cord was working right.
    Checked all the connections.
    Maybe it is the power supply?
    May it be a fuse?
    How can I test the power supply? Can any of you tell me where are the fuses in this machine so I can check them?
    Here are some pictures taken from Amazon of the same machine I bought.
    I am an architect with little knowledge in electrical issues.
    Thanks in advance for any help you can provide.
    Arqmoe (from Venezuela)
    Attached Thumbnails Attached Thumbnails NEED HELP! Chinese 60w Laser cutter won´t turn on.-71n-mdqivsl-_sl1500_-jpg   NEED HELP! Chinese 60w Laser cutter won´t turn on.-7190rkhddxl-_sl1500_-jpg   NEED HELP! Chinese 60w Laser cutter won´t turn on.-maquina_sl1500_-jpg
    Nov 2008
    Default Re: NEED HELP! Chinese 60w Laser cutter won´t turn on.
    Keep in mind that these units have a number of safeguards like door, water flow, water temperature. Maybe the manual would help. Check easy stuff before messing with electronics.
    Jul 2016
    Venezuela
    Thanks for the help. The manual didn't help. I checked everything and discovered that the power switch was malfunctioning. Changed it and solved the issue.
    Arqmoe (Architect from Caracas, Venezuela)
    Feb 2017
    Did you ever figure out what happened? I'm in the same situation right now with the exact same machine.
    Jul 2016
    Venezuela
    Quote Originally Posted by floridagirl View Post
    Yes. It was the fuse where the power cord connects into the machine. After several trial & errors, I plugged every other thing separately from the machine. changed most of the wires with ones with higher capacity. The water pump, air pump and air extractor are connected in a voltage regulator.
    Hope this helps. Sorry for the bad english.
    Apr 2018
    My machine is having the same problem, first it was the fuse. It was working fine. Then it went off again! I checked the fuse and in was still good. I don't know what it could be or how to check it. does anyone know what it could be? I could use picture too. Need Help!
