Hi All,
For those of you that are running the AWC608 DSP Controller I have a couple of questions.
1. What does the “Datum” buttons do? And how do you use them?
2. What does the “Origin” button do? Does it set the origin? Or is it meant to return the cut head to the origin?
3. When working in LaserCAD, how do you set it to cut or engrave in the bottom left corner of your work area? (or anywhere for that matter) It doesn’t seem to matter where I place my job in the work area, my laser always goes to the top right home position.
Thanks in advance for any help or guidance.
