Hi all,
I have a GCC X380 Laser Pro 120w glass tube laser.. The machine cuts accurate closer to the mirror but has a compounding loss of accuracy in both the X and Y as I move across the table. I talked with the salesguy for Laser Pro and he said it was normal to see a 1/32" loss of accuracy across the table do to lens distortion.
Is that true?
If not, isn't there a software solution that would compensate and skew the output to compensate?
Thanks for any help on this..
