Yes, that is correct. Objects that are a color that has its "Is Output" set to "no" will not be cut but will affect the extents of the cut.
Just received my laser recently and I'm still learning the RDWORKS V8 software. I have a question about skipping layers, but still use them as a bounding box. Meaning... If I have a 8x10 piece of glass or wood and I know it's dimensions. If I design something in Illustrator with an 8x10 stroke around it, is there a way to use that as my bounds for the item. That way I can butt it up to the corner of the machine at zero and it will engrave or cut only the inner design and ignore the bounding box. Basically I want to use the bounding box corner as zero and engrave only the design inside the box. Would I simply just check "IS OUTPUT" as No?
Sorry if that didn't make sense. I'm just not fully versed in laser talk yet, lol
