- Need Help!- RDWorks v8.01.18 - Fails to download to cheap Chinese Laser OCCASIONALLY
Hi Everyone,
I have one of those cheap 50W chinese laser cutters off eBay. Works fine most of the time but occasionally when I download the file to the cutter the PC says it has downloaded OK. In the file list the file is there but when I access it there is nothing. Pressing ESC gets me out of it and I can then delete the file and continue with a different file.
Has anyone else had this issue? Is there a way to resolve it? I tried clearing out all previous files etc.
Cheers
Dave Emsley
Re: RDWorks v8.01.18 - Fails to download to cheap Chinese Laser OCCASIONALLY
Dave, are you sure that the color/layer that you want to cut is not set to "Output No" in the upper right portion of RDWorks? Can you print directly (i.e. use the "Start" instead of "Download")?
- You may not post replies
- You may not edit your posts
Forum Rules
