- Need Help!- corel laser won't do what I need
Hello there
I use corel laser with coreldraw x7.
I try to say engrave a circle and cut a rectangle around it!
After engraving done laser cutter starts with cutting the rectangle but not in the place I put it and in another place!!!
How can I fix that?
I also try 2 layers but didn't work
Can someone help me out please?
Re: corel laser won't do what I need
Hello, to solve tihs issue, you have to put both engraving and cutting mode on the driver to WMF. Just right click on the engaving machine icon and go to CorelDraw settings and make the changes. Hope this helps...
- You may not post replies
- You may not edit your posts
Forum Rules
