70w laser tube
Results 1 to 6 of 6
Thread: 70w laser tube
    Apr 2007
    Colombia
    Default 70w laser tube
    Can I use a 70w laser tube with a 60w laser machine? Does the power supply work with this tube? I plan to use it at the same power ( Ma) I used the 60w ( about 23Ma.).
    thanks
    Luis
    Sep 2008
    Quote Originally Posted by lamicron View Post
    Hi Luis,
    There are NO guarantees and the risk to do the swap MUST BE entirely YOURS, but here are my thoughts on the matter...
    It should be no problem as long as the mechanical and ELECTRONIC specs of the 70W tube are the same as the 60W.
    Are they from the same manufacturer?
    Are they both RF driven?
    What RF voltage?
    What drive current?
    Is the tube diameter for mounting the same?
    Is the beam height when mounted the same?
    The optics for the 60W will work fine with the 70W as they are not dependent on power just raw beam diameter and the 60W and 70W will probably be pretty close to the same at around 1/4" diameter.
    The power supply for the 60W **may not** generate enough current to drive the 70W to full power but I would be surprised if that is the case.
    If the power supply does drive the 70W to full power then the software however will still adjust power from 0 to 100% meaning that at 50% with the 60W you would have 30W and with the 70W you will be getting 35W for a 50% setting. Experimentation will decide where you will need to adjust the burn power for the 70W.
    As I said at the start, these are my thoughts and I MAY BE COMPLETELY WRONG. So make sure you have everything well understood before doing the swap. If you do not FULLY understand what you are doing then hire someone who does.
    Given the cost of a 70W laser tube, a faulty assumption on your part could be costly. There are many many variables in driving a laser tube, it is NOT like changing a light bulb.
    Dave
    Apr 2007
    Colombia
    ok, understood, thanks!
    I´ve received and answer from the manufacturer in china, he says there is not a problem.
    The length of the 70w tube is 1.20mt , then I think the real power is 60w. as fro each 1.mt of length you get 50w . I only wanted to be sure, the real problem with these tubes is to bring it and get it in one piece.....
    Luis
    Oct 2008
    China
    Luis
    Yes,you can use the 70w tube on the 60w laser machine. The laser power supply can drive the tube.
    Alice
    Apr 2007
    Colombia
    Thanks for help,
    Luis
    Dec 2008
    china
    Default Information about the tube
    Power of Laser tube .......length of laser tube.............. work with power supply
    50W ...............1.0 m .................60W
    60W ...............1.2m-1.25m........ 60W
    70W............... 1.6m .................80W
    80W............... 1.6m .................80W
    Hope it helps.
    I'm the technical support of Redsail Laser, please feel free to contact us about your any qeustion about the laser engraver and laser cutter.
    http://www.hflaser.com
70w laser tube
70w laser tube
