Please post images of a brand new S6 or T130 laser tube
Results 1 to 10 of 10
Thread: Please post images of a brand new S6 or T130 laser tube
    Nov 2007
    Default Please post images of a brand new S6 or T130 laser tube
    Hello Everyone,
    Is there anybody out there that might be able to photograph the ends of a 130watt 80mm dia. laser tube from Reci or SPT?
    I purchased a tube and I am attempting to find out if I was sold a faulty tube, or a used/damaged tube or if it is infact new. I have nothing to compare to and there are very few detailed images online.
    I am after close up, focused , well taken images of both the anode and the cathode as well as the emitters at each end that are inside the reaction tube.
    I would be grateful if someone could help. In the mean time I will do what I can to help out whoever might need help themselves...
    Thanks in advance.
    Cheers! SW
    Jul 2016
    China
    Default Re: Please post images of a brand new S6 or T130 laser tube
    Hello SW
    Have a nice day!
    This is Lei from DWD Mechatronics Co.,Ltd,used to be service engineer of cnc router before being a salesman,i attached one picture ,this is reci 130w which i bought for my clients, please check if it can help you . If you met other machine problems about cnc router or laser, you can contact with me ,i will try my best to give you solution. My mail is :dwdcnc_lei@163.com, and whatsapp: +86-15621880878. ThanksPlease post images of a brand new S6 or T130  laser tube-reci-jpg
    Nov 2007
    Thank you for the image. unfortunately I require images of both ends of the tube. I would like to see what the outer metal connector/jacket looks like and also the emitters inside the reaction chamber.
    Thank you again..!
    I will attempt to make contact with you shortly.
    Registered SPT-Laser's Avatar
    Aug 2016
    China
    Hello,
    I'm Emily from SPT laser, manufacturing co2 laser tube.
    Below is the tube ends of T130.
    Please post images of a brand new S6 or T130  laser tube-t-tube-ends-jpg
    Emily
  5. #5
    Nov 2007
    Quote Originally Posted by SPT-Laser View Post
    Hello,
    Emily
    Thank you Emily.
    Can you show side view image of anode and cathode?
    If a tube is brand new and not used is there discoloration on cathode? yello color from heated metal? Thank you for sharing
  6. #6
    Aug 2016
    China
    Hello,
    Send me the picture of your tube ends, I will see.
  7. #7
    Nov 2007
    I have these photos. I can take better if needed....
    Please post images of a brand new S6 or T130  laser tube-anode-jpgPlease post images of a brand new S6 or T130  laser tube-cathode-jpg
  8. #8
    Aug 2016
    China
    It seems ok from the picture you sent me. It's not SPT tubes
  9. #9
    Nov 2007
    no Emily.
    This is RECI tube.it is supposed to be new and never used. I bought it a year ago. I never energized it and now when I try.it does not lase. So i bought a junk tube. I dont know what chance I have for a warranty replacement as company I bought it from says...11 month warranty. Even though I never use it. I am sad.
  10. #10
    Oct 2013
    Montreal
    I am sorry to hear this.
    If some laser tube are not sealed very well, the laser tube leaks gas gradually. The laser tube power will be decreased gradually. People could not found this problem even they test it before sending out. That's why the laser tube die even if you don't use it.
    If the laser tube is sealed well, you can still use it after storing two years.
    Thanks.
    Anna
    anna@peakofglass.com
    lyxlaser@gmail.com
