Laser CO2 Tubes, Diodes, RF and Power Supplies
Page 1 of 10 1234 ... LastLast
Threads 1 to 20 of 183
Forum: Laser CO2 Tubes, Diodes, RF and Power Supplies
Laser CO2 Tubes, Diodes, RF and Power Supplies here.
    11-16-2023, 12:00 PM Go to last post
  1. Newbie- Converting RF laser to Glass tube Co2
    Started by AussieMakerGeek‎, 10-01-2023 07:46 AM
    50w, co2, glass, laser, tube
    10-01-2023, 12:31 PM Go to last post
  2. Vytek FX2 laser module pin connections help needed
    Started by Chrisviney‎, 08-26-2023 08:34 AM
    connections, invest, laser, support, vytek
    08-26-2023, 08:34 AM Go to last post
  3. Unhappy Need Help!- 90W RECI W2 laser tube outputs concentric circles
    Started by Onedy‎, 08-11-2023 04:52 PM
    forum, it’s, i’ve, laser, power
    08-11-2023, 04:52 PM Go to last post
  4. Need Help!- Synrad T60 RF driver dead (need pics of yours)
    Started by AussieMakerGeek‎, 06-11-2023 02:25 AM
    06-12-2023, 02:09 AM Go to last post
  5. Moved: Golden Laser JGSH-13070 For Sale
    Started by RCjunkie‎, 04-13-2023 11:38 PM
  6. Converting control board from old diode to CO2 psu
    Started by horhe_‎, 02-14-2023 04:21 PM
    02-14-2023, 04:21 PM Go to last post
  7. Need help with PWM laser control in Mach3
    Started by garymiller397‎, 01-03-2020 03:06 PM
    12-01-2022, 01:55 PM Go to last post
  8. Need Help!- Wiring a Laser to my CNC using an External 12V Power Supply
    Started by dcrowder79‎, 03-15-2022 09:39 AM
    05-23-2022, 09:35 PM Go to last post
  9. Need Help!- Laser tube hisses but does not fire
    Started by jaymez10‎, 08-22-2017 11:56 AM
    fire, laser, power, test, tube
    03-03-2022, 06:49 AM Go to last post
  10. Need Help!- 100 Watt laser tube beam dia.
    Started by Lasertymes‎, 02-06-2022 07:25 PM
    2.5mm, beam, dia, laser, tube
    02-06-2022, 10:36 PM Go to last post
  11. Stepper motors and timing gears and belts.
    Started by Bpoolrock‎, 01-13-2022 09:02 PM
    belts, cnc, motor, size, stepper
    01-14-2022, 01:20 AM Go to last post
  12. Question Newbie- Why no Z travel when cutting thicker material in multiple passes?
    Started by rlrhett‎, 12-12-2021 02:49 PM
    cnc, diode laser, focus, laser, z axis
    12-14-2021, 05:31 PM Go to last post
  13. Need Help!- Invert laser TTL logic
    Started by najmpierre‎, 12-11-2021 07:34 AM
    cnc, gnd, invert, laser, ttl
    12-11-2021, 07:34 AM Go to last post
  14. Realistic life of Chinese laser tubes
    Started by SRT Mike‎, 03-22-2012 04:30 PM
    3 Pages
    1 2 3
    factors, not, since, then
    11-16-2021, 03:03 AM Go to last post
  15. Need Help!- Laser beam wobble
    Started by mcdonald79‎, 10-22-2021 01:58 PM
    10-22-2021, 03:18 PM Go to last post
    10-22-2021, 01:10 PM Go to last post
  16. diy CO2 laser tube
    Started by AndreiBogdan‎, 01-04-2021 12:04 PM
    10-15-2021, 10:51 AM Go to last post
  17. Newbie- Laser Tube Size Clarification
    Started by rlrcstr‎, 05-12-2021 05:57 PM
    hours, laser, lifetime, price, tube
    05-13-2021, 10:54 AM Go to last post
    04-26-2021, 06:17 PM Go to last post
Forum Information and Options
Moderators of this Forum
Users Browsing this Forum
There are currently 3 users browsing this forum. (0 members & 3 guests)
Thread Display Options
Use this control to limit the display of threads to those newer than the specified time frame.
Allows you to choose the data by which the thread list will be sorted.
Order threads in...
Note: when sorting by date, 'descending order' will show the newest results first.
Icon Legend
Contains unread posts
Contains no unread posts
More than 25 replies or 500 views
Hot thread with unread posts
Hot thread with no unread posts
Closed Thread
Thread is closed
Thread Contains a Message Written By You
You have posted in this thread
