| Knee Vertical Mills Discuss Knee Vertical Mills here. |
Have a Lagunmatic Mill with a Delta 20 controller. If it sits for a couple of hours then everything in memory clears including the settings and zeros. I can feed code via RS232 and the machine runs but if i leave and come back the controller loses its settings. does anyone have any experience with this problem and/or know how to fix it? Thanks, Max the pics is close to the same machine, it has the same controller.... ![]() reposted in machine problems topic.... Last edited by maxoverclock; 12-16-2009 at 07:09 AM. |
Yes, change the battery. It's inside the card rack. Take off the fron aluminum cover and you will see it in a black holder with a little rubber strap around it. Looks like a AA, but if I remember correctly its a 3 volt lithium battery. You can pull the board out if you need to. Dynapath has all the PIC tables loaded on a eprom. |
| Delta Tau Anyone | Al_The_Man | General CNC (Mill and Lathe) Control Software (NC) | 21 | 01-14-2010 01:08 PM |
| Newbie- Hold to hold tool holder while loosening nut | NXTwoThou | CNC Tooling | 2 | 02-24-2009 03:15 PM |
| Delta-Wye (Wye-Delta)? | JasonCampbell | Servo Motors and Drives | 0 | 10-09-2007 04:43 AM |
| Wye-delta, delta-wye configurations? | mackeym | Phase Converters and VFD | 10 | 09-27-2006 05:02 PM |
| delta tau | Jeremiah | Servo Motors and Drives | 9 | 06-22-2006 07:41 PM |
