Results 1 to 2 of 2
Thread: Cnc Masters or Any chinese mill spindle bearing upgrades
    Apr 2007
    Does any know how to remove the spindle bearing in a chinese mill? I recently purchased a mill that was supposedly new, however it had sat on a loading dock for a while and was claimed as lost freight.
    When i started it up the spindle bearing were noisy, i callednc Masters to see how they suggested to lubricate these spindle bearings.
    They told me to remove the id plate on the front and filli this area with 50weight oil, however what happens is the oil runs out into everything, because the machine was poorly designed without any thought to spindle bearing lubrication, and there is no seal to hold the oil from leaking out onto everyhting within a short period of time. You would have thought that they would have installed a bearing that was sealed and prelubed, or an oil seal below the bearing to hold the lubricant there where it's needed.
    I'm curious if anyone has modified this part of one of these mills with a better bearing system, or if someone would help out and tell me what is entailed in removing the spindle so i may inspect these bearings and maybe come up with an idea of my own.
    I'm sure if i can get the spindle out, i can fit a different bearing or have a seal made.
    Please help. I do have a nsk air spindle that i may elect to use, however, I do see some uses for this spindle also.
    BTD
    BTD is offline
    Aug 2009
    I also have a cheap chinese/taiwanese mill. Like your's, when you lube the spindle, the oil runs out onto the table. My owner's manual (another real joke) basically states that you have to give the spindle oil cup a squirt everytime you use the mill. It's really no big deal to do this but just seems like a crappy way to build a machine.
  1. CNC Masters Supra Knee Mill
    By Martin 007 in forum Knee Vertical Mills
    Last Post: 05-09-2013, 06:23 AM
  2. CHINESE SPINDLE 2.2KW
    By Ed Williams in forum Open Source CNC Machine Designs
    Last Post: 12-28-2012, 12:01 PM
  3. 2.2 KW Chinese Spindle ? runout
    By Ed Williams in forum DIY CNC Router Table Machines
    Last Post: 09-23-2009, 12:52 PM
  4. CNC MASTERS Baron Mill
    By pvellenga in forum Benchtop Machines
    Last Post: 02-10-2009, 07:26 PM
