Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Knee Vertical Mills
Knee Vertical Mills Discuss Knee Vertical Mills here.
Old 09-25-2009, 06:00 PM
wganders is on a distinguished road
Replacing the leadscrew nuts on a Lagun Mill
We have a Lagun Vertical Knee Mill with a SWI Trak 2 CNC control on it. We are replacing the nuts on the X and Y axis due to backlash. Does anyone have any ideas on how to remove the table without damaging the glass scale and reading head? I was just going to remove the end-piece on the scale cover and let the head just slide out.
Also, the X-axis seems easy to replace the nut but the Y seems a little more involved, any ideas?
Finally, any suggestions as to how to recondition the ways on a budget? They show some galling.
Thanks,
Wanders
Old 10-03-2009, 01:01 AM
chevdrgtrk is on a distinguished road
I actually just put in ball screws in my Enco....I don't have the glass scales, but can you just remove them from the machine? If so I would really suggest that. I didn't take off my home or limit switches when I removed my table, and I ended up trashing one of them. On the Y, when you get the table off, you can remove the Y screw completley from the machine, then the yoke will be able to come out of the top.
Old 10-06-2009, 10:10 AM
Davo J is on a distinguished road
wanders
Dont take the reader head out of the scale body, take the whole scale with reader head together off the machine, otherwise you run the risk of ruining the scale.
Davo
Old 12-17-2009, 01:42 PM
cheetahcnc's Avatar
cheetahcnc is on a distinguished road
Thanks,
Wanders
Did you get the lead screw nuts replaced? I have a set to do on my Lagun as well. You remove the four bolts from the bearing mount casting and unscrew the assembly from the nut. There is a manual offered from Lagun for $75, and you can occasionally find them on ebay for $50 or less.
Jim
Old 01-18-2010, 07:44 PM
hansw3 is on a distinguished road
Is there a way to tighten up the backlash on the Laguns? I have a manual FTV-1 and so far it is proving to be smarter than me. There's two screws on the y-axis nut- a S.H.C.S. and a flat head. Neither one does anything...
Old 01-18-2010, 11:27 PM
Welll I tore into it and pulled the front bearing off and then unscrewed the leadscrew to get a better look. The brass busing half nut is shot. I need to get a new one.
Anyone know part number for it? The machine serial # is 18005 if that helps.
Here is a picture of the half nut:
http://picasaweb.google.com/hansw3/L...17246975546242
Tags
glass scales, lagun, mill, repair, ways
Lagun Mill/parts availability Ted383 General Metal Working Machines 13 11-13-2009 01:24 PM
Problem- Leveling a Lagun Vertical Mill donl517 General Metal Working Machines 2 12-14-2008 12:41 PM
Lagun mill powered knee jjclear Knee Vertical Mills 3 12-03-2008 01:29 PM
Urethane Resin Casting: Linear Glides & Leadscrew Nuts scratch_6057 DIY-CNC Router Table Machines 2 03-26-2006 01:13 PM
Precision Nuts for stock leadscrew kdoney Benchtop Machines 11 02-14-2006 04:12 PM
